1 - 20 of 92 Posts
o boy, here we go again with an oil argument, use the search button, that being said:
many people have had good luck with Mobil 1 synthetic, others have used royal purple, quaker, etc.
What is the best weight to use for all around weather? 5w30, 10w30? I'm too lazy to go look in my owners manual. :p
I'm using German Castrol Syntec 0w30. I switched from regular 5w30 Syntec. Only 300 miles on it so far, but the car likes it.
My car liked to drink Mobil 1 5w30.
royal purple FTW
Just talking about this tonight, I switched from Mobil 1 to castrol syntec just to check it out... Mobil 1 burned quick and needed to be added halfway between intervals, and looked like sludge when draining at 3k. Castrol didn't burn a drop and looked clean after 3.5k. Thinking about a permanent switch????
try royal purple syn.....you'll never go back mobil 1 or castrol
5w 30 when cold.
10w 30 in summer.
if your too lazy to switch go 5w30 all the time.
The manual calls for 5W-30.
I use Mobil 1 synthetic.
Gunnin' it.
Quaker Synthetic...I always thought those commercials were bs, but it actually does let all of your horses out. Q FTW!!
+1 for german castrol synthetic 0w30
I use Amsoil with their special filter.
EL
I usually use Mobil 1 5w 30, but I'll probably try the royal purple this coming oil change. I've got to do one soon and a place near my house sells it, so I'll give it a try.
Amsoil 5w30
For some reason it seems like our cars really don't like Mobil 1 based on how many people have problems with the engine making it disappear. Castrol has been good for me so far. The only oil the engine loses gets lost through the worn out crush washer on the drain plug that I need to replace.
Do you have oil analysis results suggesting that Royal Purple is *that* much better than Mobil 1 or Castrol?
LightWerkz said:
I noticed Mobil 1 burns too fast. Switched to Castrol Syntec and couldnt be happier. However I am trying Royal Purple Tmrw..
u'll love it man
1 - 20 of 92 Posts
