Re: Baron's '05 STi journal - **Motor is comin' out again...coolant leaks...**
I messaged someone I sorta know that recently started at IAG, which always leaves me wondering why I do message him afterwards... I sent him a link for the post on the bearings and his response is was that it was "as simple as someone writing the wrong thing". Sound good, right? Well, maybe? He then talks about a 25-person team producing 10 engines a day, but now I'm led to believe the mistake was in the writing?
He then asked if I had anything to do with the build, when I said I am physically not there. I mentioned that I didn't think it should leak sitting on the stand with zero pressure. He said that "the head was basically made into a surface as similar to concrete, thousands of tiny little pores". I don't think he understands concrete pores (which are throughout an entire slab) vs surface dimples in a head, but I degress. It went on but in his defensiveness, where I haven't pointed any fingers, I told him to disregard.
That said, the head absolutely should have been surfaced properly, but with a coated gasket, I personally do not see it as something that should leak in this specific situation since the coating only has to seal the high points of the surface since there aren't actual "pores" from blasting. I say this because it does have me wondering if there is another issue in there, without pointing any fingers. It's worth a look into parts and installation procedures when redoing it with properly surfaced heads and new head gaskets (and why don't you have the stronger head studs on a closed deck block and 1000hp rods?).
