1 - 7 of 7 Posts
Can the AP be programmed to do other functions..exmpl it reads live boost, but how about EGT's or AFR's. Would be cool if it Data logged
if you have a laptop and a few minutes, you can download ECUexplorer from TARIS, and you can log everything, using the AP cable.
www.openecu.com
Have fun
Will the boost readout be limited to the same 18.3 limit? I'm guessing yes.
Discussion Starter · #6 ·
Ah ha, got it...it's .org not .com. So we can only use the data log portion of it? What about the flash options??? The guide said it's not compatable with usdm versions and the 2006 models? Can the 2005 and earlier use it?
And what about the other edit programs on openecu.org?
yeah, sorry about that, its its www.openecu.org
ecuExplorer allows you to log, there's another one there called ECUedit. The free, demo version allows you to log, as well as tweak a few small things, like timing, idle speeds etc.
If you wanna go hardcore, you have to buy the full version, or you can drop $120 and get Cobb Street tuner.
1 - 7 of 7 Posts
