1 - 13 of 13 Posts
So what Amsoil filter you recommending for the STi? My Amsoil guy was not aware of the 080 filter so I think the filters he recommends are for the WRX. Does it really matter?
Discussion Starter · #4 ·
I pulled this from an STi owner's post at Clubwrx ....
"SDF20, I have been using amsoil OIL and filters for years on my cars and bikes.
The filter fits perfect and is a bit bigger.
SDF20"
That is what my guy said. He came up with 2 filters and said the he would go with the SDF20 since it was bigger. Thanks.
Warranty and modifications??
Update!
Another back to back test was done, on the same 1994 Toyota Supra Twin Turbo.
With 3 Gallons of Torco's Race Fuel Concentrate mixture left in the tank, the supra made 439 HP to to rear wheels :eek: . (Originally, 32oz were added to 10 gallons, so this was left over)
Then, 5 gallons of C-16, 117 MON Octane (yeah the $7.00+ per gallon stuff) was added, to do another pull.
It pulled 448 HP to the wheels, same boost, same everything.
What does that mean? Sure, the C-16 made 9 more HP, but was it worth it? Well, the Concentrate certainly is not as great as C-16, but it is definitely more cost effective, and it works.
I'll be posting the dyno runs from today's pulls on the website by the end of the week-end.
Sorry, with the Concentrate, it did 439 HP to the wheels, and it did 448 HP with the C-16.
Can you not edit your previous posts?
Discussion Starter · #9 ·
I will have more stock of the Unleaded formula shortly ... probably around the 15th of this month .....
I will also offer some sort of special for you to try it out .....
Discussion Starter · #11 ·
Sorry for the late reply .... here's what we can get:
1996 TOYOTA SUPRA 3.0L 6-cyl VIN Code 5 2JZ-GTE
FILTERS
Oil Filter......SDF57
Oil Vapor Filter......N/R
Air Filter......TS115
Fuel Filter......GF269
Fuel Vapor Filter......N/R
PCV Valve......HV168
Trans......TF134, Turbo
Trans......TF96, ExceptTurbo
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SL
Series 2000 Synthetic 0W-30 Motor Oil (TSO)
SAE 5W-30 SYNTHETIC MOTOR OIL (ASL)
Synthetic XL-7500 Motor Oil (XLF, XLM, XLT)
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil (HDD)
Grade 2......API*
Above 0°F......10W-30
Below 50°F......5W-30
Manual Transmission,.....GLS[1]
Synthetic Gear Lubes (AGR, AGL, AGT, ALU, AGO)
Series 2000 Synthetic Gear Lube (TGR)
Automatic Transmission.....TIV[2]
Special Lubricant Fluid - Not Available Through Amsoil Click here for more information
Differential, Rear .....GL-5
Below -18°C......80, 80W-90
Fluids
Power Steering Fluid.....AF3
Synthetic Automatic Transmission Fluid (ATF)
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3, DOT-4 or SAE J1703 - Not Available Through Amsoil Click here for more information
Clutch Fluid.....HB
1. GLS is a special gear lube, Toyota part no. 08885-01306.
2. TIV is Type T-IV Automatic Transmission Fluid,
(ATF JWS3309 or NWS6500), Toyota part no. 08886-01705
Sorry for all the detail stuff, that's what the application guide shows.
Let me know if you have any questions.
Thanks,
Brett
Discussion Starter · #13 ·
Sorry, I have mis-placed my STi manual ... what are the Fluid requirements + types for Tranny and Diff? I'm sure we carry something ....
1 - 13 of 13 Posts
