1 - 3 of 3 Posts
The goal of this product is simple, the removal of oil (in liquid or vapor form) from the vented crankcase gasses.
This is accomplished by using a design that has no restrictions; media or baffles, to reduce the flow potential of the crankcase and head vents. Our air oil separator differs from any other on the market. We use centrifugal force to pull oil and liquid vapors out of crankcase gases. This will insure the best possible separation available. Like a tornado, our system pulls vacuum from the center of the separator with the pressured gasses from the crankcase entering an obstruction free path maintaining the most velocity. This causes the heavy vapors to fall out of suspension. It functions with a vacuum source from the turbo inlet. Drain back design assures that any oil accumulation ends up in the oil pan, providing a consistent oil supply to the engine.
Six stainless steel bolts on the top, make it quick and easy for inspection and cleaning. It is not heated, and we see no reason to add unnecessary cooling/heating (weight, complexity, increased install time, and increase probability of something leaking). The Killer B Motorsport Air/Oil Separator should meet and exceeds your expectations of form and function. Our Air/Oil Separator is a product that enthusiasts have been waiting for.
1 - 3 of 3 Posts
