A few people have asked so here's my build. This is my first foray into the Subaru world though not my first trip into the turbo 4 cyl awd world as my name might hint at. I've built a few dsm's, a z32 tt 300zx, svt cobra and s13 in the past. I always liked wrx's but knew myself well enough to know anything short of a STI wouldn't keep me happy for long. I picked up my current car off ebay right before covid shut everything down. 107k miles, intake, cat back, AP3 installed, supposedly low compression in 1 cylinder, $8k plus shipping from the west coast. The car showed up maybe a week before the initial covid shut downs took place. First start had smoke billowing out of the exhaust and what sounded like popcorn popping under the hood. I'm not completely inept when it comes to cars but i knew doing the motor was going to be more than i was prepared to tackle. Stopped at a few places while waiting for the car to arrive and was shocked at the costs i was being given to prep something to break 400 whp after a turbo upgrade down the road.
I ended up settling on a local place called Area1320 in Nazareth PA to do the work. They're the closest Subaru specialty shop and they're an IAG certified installer. I started collecting parts as i found deals on them as my date to go in for the build was still several months off. Unfortunately due to all the shut downs shipping delays and places just plain being out of stock meant what was supposed to be a 2-3 month long build turned into a 2 year build. Over this time as i kept doing research and finding deals on more parts the build just kept growing. It was always intend to be a full street car. Something responsive that is a joy to take on my favorite back roads and to the autocross when they come to town.
When they finally cracked into my motor it was pretty clear that there were more problems besides 1 cylinder with low compression. 1 piston had a cracked ring land. Another has the edge of the piston crown literally explode upward into the cylinder. Metal chunks damaged 1 head beyond repair, turbo was smoked and tons of oil in the tmic. I'll get a picture of the piston next time i visit my builder. They keep it on their front desk as it's the worst they've ever seen before.
There isn't an area of the car that hasn't been touched at this point. To the best of my knowledge this list of parts below is accurate.
Turbo/Intake/Exhaust
- Boost Lab 54XR+ 66 lb/min turbo, 3” T51 inlet, .83 v-band ex. housing.
- 3” v-band downpipe w/ gesi cat
- Torque Solutions downpipe thermal blanket
- Custom air intake
- DEI turbo blanket
- Tomei ELH, SwainTech coated & gaskets
- Custom rotated up-pipe for v-band w/ 38mm external gate
- Up pipe blanket
- Tial MV-SBK 38mm external wastegate w/1 bar spring, routed into downpipe
- Full Race Tial heat blanket
- Custom resonated mid pipe
- ARK GRiP cat back exhaust
- ETS 4” FMIC w/ custom piping
- IAG 74mm throttle body
- Tial Q bov, black, 10 psi spring, burnt titanium hardware
- Radium dual injector TGV’s w/ 8mm phenolic lower gasket & hardware
- NA intake manifold port matched to tgv’s, wrinkle black
- Grimmspeed intake manifold to TGV gasket
- Torque Solutions 12mm exhaust mount kit
- Reflect-A-Gold high temp reflective tape
- Area1320 3 port EBCS
Sensors/Gauges
- Aem 5 bar map sensor w/ torque solutions bolt on adapter
- Plug-n-Play IAT sensor/speed density kit
- AEM WBO2/Boost gauge combo w/ drivers side vent mount
- Innovate Motorsports 3913 MTX-D oil pressure/temp gauge kit
- Innovate Motorsports 3851 MTX-D boost/shift light gauge kit
- Cobb flex fuel kit
- Cobb fuel pressure sensor
- Cobb AP V3
Fuel
- IAG v3 fuel rails
- IAG braided fuel lines
- Injector Dynamics ID1700x injectors w/ plugs
- Radium Engineering dual pump fuel hanger w/ aem 50-1200 fuel pumps
- Radium Engineering fuel hanger dual pump plumbing kit
- iWire plug n play dual pump wiring harness
- Radium Engineering high flow fuel filter w/ 10 micron filter & 1pc heat exchange clamp
- Fragola 602008 -8 PTFE feed fuel line
- Fragola 602006 -6 PTFE return fuel line
- Fragola/Aeromotive AN fittings, ethanol safe
- AEM AFPR
Engine
- IAG Stage 2.5 short block w/ ½” head studs
- Headgames Motorworks pocket ported/assembled heads
- New OEM 11039AC070 right cylinder head casting
- New OEM 11063AB480 left cylinder head casting
- Brian Crower BC0600S valve springs & steel retainers
- GSC 2012-8 36mm in. valves
- GSC 2011-8 32mm ex. valves
- GSC OEM replacement valve seat set
- GSC 6mm valve guides
- Brian Crower BC2960 valve guide single groove stem keepers
- Brian Crower BC0623 cams
- Viton valve stem seals
- ATI 917991 super harmonic damper
- Torque Solutions secondary air pump block offs
- Company 23 EJ257 timing belt guide kit
- Perrin air oil separator
- IAG Stage 2 oil pump
- Aisin TKF-004 engine timing belt kit w/ new water pump
- ARP ½” head stud kit
- Group N motor/trans mounts
- Pitch mount
- Mishimoto X-line radiator
- Perrin wrinkle black overflow tank
- Aluminati black expansion tank
- Mishimoto black silicone radiator hoses
- Mishimoto thermostat
- Mishimoto black battery tie down
- SuperStik black dipstick
- Dress Up Bolts titanium engine bay kit, black
- WC Lathe Werks burnt titanium oil fill cap
- WC Lathe Werks burnt titanium alternator cover
- WC Lathe Werks titanium radiator stays
- RK Titanium burnt titanium upper radiator pipe
- JD Customs windshield washer, brake reservoir & clutch reservoir burnt titanium caps
Drivetrain
- ACT T1S-S05-Mod-Twin 225 twin disc clutch kit w/ lightweight flywheel
- Driveshaft Shop SUSH9-C carbon fiber driveshaft w/ 10mm bolts
- 34110VA121 2015-2017 STI 13:1 quick ratio steering rack
- Torque Solutions transmission member bushings
- Torque Solutions positive shift kit
- Torque Solutions shifter linkage bushings
- Torque Solutions solid shifter linkage U-joint
- Torque Solutions clutch master cylinder brace
- Torque Solutions TS-SU-427BK billet rear differential brace
- Torque Solutions TS-SU-603 rear differential lockdown system
- Goodridge SS clutch line
- Goodridge SS brake lines
- Hawk HPS+ brake pads
- EBC slotted rotors
- Perrin PSP-BRK-401BK brake master cylinder brace
- ITS transmission pedal support bracket
- Arp 100-7727 wheel stud kits
- Mishimoto black aluminum wheel lugs w/ locks
- SSTI burnt titanium wheel lugs
- DarkMatterX DM-1 Shifter assembly
- 18 x 9.5 Enkei RPF1’s, 38mm offset
- 255/40 Michelin Pilot Sport A/S 4’s
- 8mm wheel spacers
Suspension
- Tein VSSB02-D1SS4 Flex A coilovers
- Tein EDK04-Q0349 edfc active pro controller
- Tein EDK05-12140 edfc motor kit
- Tein EDK06-K4474 strut kit
- Tein EDK07-P8022 edfc active gps kit
- Swift 7k front & rear springs
- Eibach front & rear sway bars w/ poly bushings
- Whiteline rear sway bar bracing
- Torque Solution front & rear end links
- Torque Solutions steering rack brace
- Whiteline KSR207 rack & pinion poly bushings
- Whiteline KCA425 control arm lower inner rear bushings
- Whiteline KCA334 control arm anti lift kit/lower inner rear bushings
- Whiteline W0506 front control arm bushings
- Whiteline KDT902 cross member bushings
- Whiteline W63394 control arm bushing
- Whiteline WEC081 rear essentials vehicle kit
- KCA326 rear camber adjustment bushings
- KDT905 rear differential power positive front kit
- KDT906 rear differential positive power kit
- KDT907 rear subframe positive traction kit
- W0568 rear trailing arm front bushings
- Whiteline KDT903 rear differential mount bushings
- Whiteline KBR14 front control arm brace
- Whiteline KBR15 rear sway bar brace
- Whiteline KBR16 rear sway bar brace, link support
- Whiteline W0568 rear trailing arm bushings
- Whiteline W63225 rear control arm bushing
- Whiteline W0508 front control arm lower inner bushings
- Whiteline W53353 front control arm lower inner rear bushings
- Whiteline W63412 rear control arm upper outer bushings
- Whiteline KCA313 roll center/bump steer correction kit
- Whiteline KTA147B rear toe arm
- Whiteline KTA216A rear lower control arms
- Megan Racing front lower 'H' brace
- Cusco 692-492-FM front member brace
- Cusco 687-492-RS floor rear side braces
- Cusco 692-49-RM rear member brace
- Cusco 692-492-R rear floor brace
- Cusco 692-492-M front cross member
- Ultra Racing UR-SD8-1337 8 pt side lower brace
- Ultra Racing UR-ML4-1336p 4 pt mid lower brace
- Kein KSUB026 fender reinforcement braces
- SPT SOA8431130 front strut tower bar
- Megan MR-SB-SI08RU1P rear strut tower bar
- CF front lip
- Seibon CF hood
- CF Varis hood struts for JDM aluminum hood
- RPG CF bumper vents
- CF side skirt extensions
- CF wing extension
- GoGoCarbon rear tailgate garnish
- CF b/c pillars
- Seibon cf front fenders
- Valenti red/clear jeweled tail lights
- Torque solutions billet tpms valve stem kit, black
- WC Lathe Works burnt titanium fender badges
Interior
- WC Lathe Werks burnt titanium shift knob
- WC Lathe Werks burnt titanium SI drive cover
- SSCO wrinkle black aluminum reverse lockout
- SSCO burnt titanium e-brake button
- SSCO perforated black leather shift boot w/ red stitching
- SSCO perforated black leather e-brake boot w/ red stitching
- SSCO black leather armrest cover w/ red stitching
- OEM pop up arm rest
- GoGoCarbon D shaped steering wheel
- SMY dual gauge pod cluster surround
- Intertek Fabrications CF dash/vent/door handle trim, shifter surround & window switch panels
- JDMuscle CF center console cover
- Alpine Type R 6.5” speakers
- Idoing android head unit
The car is an absolute beast on the street. 543 hp/503 tq @ 27 psi on e65 on a local mustang dyno that's known to be a bit of a heartbreaker. On pump gas is makes about 470 hp/420 tq. Even at wastegate pressure on e65 it breaks 400 whp. There are definitely a few things i still want to do. Mostly cosmetic stuff. I have a thing for carbon fiber and burnt titanium. I'm currently waiting for ACT to get me a new sprung hub for my clutch as 1 of the springs managed to pop out after only 4000 miles or so. Once that's fixed i'll be looking forward to when the dragstrip opens again in the spring. I really just want an easy low 11 second street car. No messing with anything other than the dampening on the coil overs. From how it feels i don't think that should be an issue.
