1 - 1 of 1 Posts
600awhp 2014 Subaru Impreza WRX STi in Dark Gray with 43K (Chassis/Drivetrain) miles for sale! Only 500 miles on the IAG Stage 3 Long Block (rated at 1000hp), the Long Block does have a 1 year/12K mile warranty! This freshly built STi is equipped with a ton of upgrades, including an ETS Rotated Turbo Kit, PTE 6266 Gen II BB, Visconti 525lph Fuel Basket Upgrade, P&L Triple Disc Clutch and much more! Professionally built by Shift Fast Motorsports and tuned by JrTuned! The car can be turned up with a bigger turbo and surge tank! Mileage will climb slowly as it's weekend driven. Recent oil change with Motul 300 V Power 5W40, trans/diff with Motul 300 Gear Oil. Open to trades. Clean title! Serious inquiries contact Jim at [email protected].
for picture instagram @2muchsaucejimmyboi
Engine:
IAG Stage 3 Long Block (fully loaded)
Multi Angle IAG Valve Job
Resurfaced Heads
Kelford 220c Cams
Manley 33mm Exhaust Valves
Manley 37mm Race Flow Intake Valves
GSC Beehive Springs & Titanium Retainers
Cosworth 1.1mm Head Gasket
FHI Valve Cover Gasket
FHI Cam Seals
Case Halves, Converter to Closed Deck Using Brand New Subaru OEM Case Valves, Bored & Honed to 99.75mm
Machine Case to Fit 1/2" Head Studs
Manley Turbo Tuff 99.75mm Pistons
Manley Turbo Tuff I-Beam Rods
ACL Race Bearings
New Subaru Nitride Treated 17+ STI Crank
New Case/Main Bolts
Extreme .210 Wrist Pins
625+ ARP Rod Bolts
Perrin Crank Pulley
Killer Bee Oil Pan, Baffle & Pick Up Kit
IAG AOS Comp Series
Mishimoto Radiator Kit
Turbo System:
PTE 6266 Gen II BB
PTE Exhaust Manifold/Headers
ETS 4" Front Mount Kit
Fuel System:
ID2000 Injectors
Aeromotive FPR
Visconti Subaru 525lph Fuel Basket Upgrade
Exhaust:
Invidia N1 Catback
Drivetrain:
P&L Triple Disc Clutch w/ Track Flywheels
Torque Solutions Trans & Motor Mounts
Wheels:
18x9.5 Enkei RPF1 Wheels (one broken due to hitting a pot hole)
18x9.5 +35 Works CR Kai Wheels
Stock Wheels Included
Interior:
AEM AFR, Oil Pressure & Boost Gauges
COBB Accessport V3 Flex Fuel Dated
Dyno:
490awhp on 93 Octane
600awhp on E70-85% conservative tune
Price: $30,000 OBO
1 - 1 of 1 Posts
