1 - 6 of 6 Posts
2020 STI Limited
Hey, I have a IAG Stage 2.5 short block with an AEM 340lph fuel pump, Aeromotive FPR, 6AN lines, SMY fuel rails, Cobb 1050 injectors, and a flex sensor on my stock turbo. I'm planning on getting the Blouch Dominator 5.0XTR Turbo. My power goal is 600 wheel on E85. What size injectors should I get and what fuel pump should I get? And would I need to get duel pumps to make this work. I already have all the supporting mods to make that power besides the Turbo and Fuel system. Any feedback is aprecciated
Radium Engineering and iWire are your friends
You need one of these - 20-0780-00 Late Subaru Fuel Hanger, Pumps Not Included, Walbro GSS342 or AEM 50-1200
One of these - 20-0629-05 Fuel Plumbing Kit, 08-21 Subaru, Microglass
One of these - 20-0236 adjustable pressure switch
Two AEM 340 pumps
iWire dual radium hanger wiring harness
2020 STI Limited
Two AEM 340 pumps
Any idea what size injectors I should get? Also would I need to get another aem 340 or get the arm50-1200 or Walbro GSS342
You could get away with a set of Injector Dynamics ID1300's but you would be at the edge of them. The next step up are Injector Dynamics ID1700-XDS.
Font Material property Parallel Number Screenshot
Use another AEM 340 as the second pump.
I'm running FIC 1440's on E, at 550 wheel and am around 70% IDC. You don't need to spend the money on Injector Dynamics and 1440's will get you there. Can always bump fuel base pressure slightly, as needed.
I'm running a dw65c feeding a radium surge tank with an Aeromotive 340lph pump with -8 AN line.
Just don't run your fuel lines paralled--do a -8 line in a stock configuration.
1 - 6 of 6 Posts
