Kia Ora from New Zealand!
Currently in the process of getting this thing fast(er), so before I go asking questions I thought a build thread would help!
Car is flex-fuel tuned with dyno sheet below (E85).
326kw on E85
303kw on 98 (RON)
Interior:
DAMD Flat-Bottom Steering Wheel
ATI Triple Gauge Holder
Defi Gauges
Full Carbon Fibre Interior
IDoing Android Headunit (Running DashCommand w/ Wifi OBD)
SSCO Shifter/Handbrake Boots w/ Red Stitch
SSCO Climate Rings
SSCO Reverse-Lockout
AliExpress Red Carbon Shift Knob
DMND Si-Drive Ring
KAP Industries Fire Extinguisher Mount + Generic Extinguisher
Chassis/Handling:
Enkei PF01 18x9 +35
Bridgestone Potenza Sport 265/35/18
DBA4000 Rotors Front/Rear
Hawk XP650 Brake Pads
Cusco Front Member Brace
Cusco Floor Center Brace
Cusco Lower Arm Brace
Cusco Rear Floor Brace
Cusco Front Strut Tower Brace
Cusco Rear Strut Tower Brace
Cusco Rear Member Side Brace
Cusco Rear Member Brace
Cusco Braided Clutch Line
Cusco Rear Diff Cradle/Brace
Cusco Adjustable Rear Lateral Links
Cusco Power Brace Rear End
Cusco Steering Rack Brace
Cusco Stainless Clutch Hose
Cusco Brake Cylinder Stopper
Grimmspeed FMIC Compatible Front Member Brace (Crashbar)
Grimmspeed Pitch Stop Mount
Whiteline Rear Diff Bushing Kit
Whiteline Rear Subframe Bushing Kit
Whiteline Front Gearbox Mount Bushings
Whiteline Front Sway Bar - 24mm 2 Point Adjustable
Whiteline Rear Sway Bar - 24mm 3 Point Adjustable
Whiteline Steering Rack Bushings
Whiteline Shifter Bushing Kit
Kartboy Short-Shifter Upgrade
Kartboy Endlinks Front/Rear
Group N Transmission Mount
Group N Engine Mounts
Block:
EJ207 W20C (Closed Deck S20C Block Replacement)
Subaru STI 2.5L Black Nitride Crank Shaft
JE Subaru EJ20 Forged Stroker Piston Set Bore Size: .5 oversize, Compression Ratio: 8.5:1
Manley Subaru WRX/STI (EJ18/20/22/25) H Beam Connecting Rod Set
ARP 625+ Custom Age Subaru EJ20/25 Head Stud
Subaru EJ20/EJ22/EJ25 (For Rear Thrust) (Size STD) Performance Main Bearing Set
Subaru EJ20/EJ22/EJ25 (Size STD) Tri-Metal Perf Rod Bearing Set
12mm Oil Pump
PBMS Oil Gallery Modification
PBMS Stage 1 Baffled Sump
IAG Timing Belt Guide
Fluidampr Subaru EJ Series Steel Internally Balanced Damper
Killer B Motorsport Ultimate Oil Pickup
Killer B Oil Baffle
Heads:
Performance Valve Seat Reface
PBMS Stage 1 Cylinder Head Porting
Heavy Duty Valve springs drop in
Kelford Cams 272 V11
IAG TGV Delete Kit
Turbo/Intake:
Blouch Dominator 1.5XTR Twin Scroll 10cm 3" inlet
Killer B EJ Cast Aluminum Turbo Inlet 3"
Process West Front Mount intercooler kit - Black
Turbosmart BOV Race Port GEN V Black
Radium Engineering Subaru STi Air Oil Separator Kit
Fuel:
ID1300X Injectors
Radium Surge Tank
Turbosmart Fuel Filter & Billet Bracket
Link Flex-Fuel Ethanol Content Sensor
Radium Fuel Rail / Line
Drivetrain:
Xtreme Extra Heavy Duty Organic Clutch kit with upgraded pressure plate
Other:
Killer B Upper Coolant Fill Tank
Engine Management:
Emtron KV8 ECU
Pics and stories here ADDCTV WRX STi (@addctv.wrx) • Instagram photos and videos
E85:
Pump Gas:
326kw on E85
303kw on 98 (RON)
Interior:
Defi Gauges
SSCO Climate Rings
DMND Si-Drive Ring
Chassis/Handling:
Enkei PF01 18x9 +35
Block:
12mm Oil Pump
Killer B Oil Baffle
Heads:
IAG TGV Delete Kit
Turbo/Intake:
Fuel:
ID1300X Injectors
Radium Surge Tank
Drivetrain:
Other:
Engine Management:
Emtron KV8 ECU
E85:
Pump Gas:
