2019 sti OEM wheels
1 reading
272 views 4 replies 3 participants last post by  knyg
#1 ·
Hi guys
Struggling to get the info I'm after.
Im running the 2020 sti oem wheels with 20mm spacers. The car has 31,000km and still running the oem Bridgestone tyres. In fact I ran a 10.6 quarter mile with those tyres on 18psi
The standard profile is a 245/35/19
And I would love to run a 255/35/19 or even a 255/40/19. Had anyone done this or any similar combination on the oem wheels.
I'm looking for a chunky meaty tyre look
As the car sits now the wheels are flush to the guard due to the spacers which look fantastic
#2 ·
Stock height?
owns 2019 Subaru WRX STI Base FP Green Flex Fuel
#4 ·
How much are you lowered? I’m about 3/4” lower on RCE Yellows, I had 20mm spacers and I was gonna run either 255 or 265/35/19’s. But I ended up with 18x9.5 Rays with 275/35/18’s
#5 · (Edited)
OEM tires arent Bridgestone. All of these numbers are actual measurements so you can actually measure it yourself.
Maximum width for a 8.5" rim (OEM width, I think) are 255 tires. Anything more is a much higher chance to debead.
With 255 or 245 tire width, you can go whatever aspect ratio ( 35, 45, 60) you want with coilovers. You will just need to adjust height and camber accordingly.
