1 - 3 of 3 Posts
Ive noticed that sometimes at a red light my 2019 sti would sometimes have the rpm "bounce" which I now understand is seen as normal on these cars. However I more recently noticed that my vacuum at idle fluctates rapidly by about a pound to a pound and half. This only happens sometimes and only when the a/c is off. I also notice it happens when the car is on more of an icline. I did notice this when it got colder outside so could these be a factor? The only mods I have done is a perrin pitch stop mount which I had to take the intercooler off to install but made sure to tighten down correctly. The car has always had an idle vacuum fluctuation of .3 of a pound. I took it to a subaru tech and they said "nothing was noticed". Can anyone advise anything about the fluctuating vacuum?
If the car is driving normally and performing as designed then i wouldnt worry about it. BTW why did you make 4 of the same exact threads on here about this.
Not uncommon or unusual. At low load and low temps the TGVs may be cycling, cams moving some, etc... The car is constantly making small adjustments. I wouldn't put too much thought into it.
1 - 3 of 3 Posts
