1 - 18 of 18 Posts
2019 Pure Red STI Limited
57945
57942
57943
57944
57946
57947
Exterior mod list:
JDM S208/S209 front bezels
JDM S4 satin mirror caps
JDM exhaust finisher
GCS Rear under spoiler (Require new bolts for a proper install)
JDM Station STI etched scuffguard door sills
Grimmspeed license relocator
Door jamb cover set
Bumper hole plugs by SubiBros
Cusco IC grille
Summer wheels: 19" Enkei Raijin with modified STI center cap
JDM rear fog/brake light & kit by SubiBros (12/07/19)
Interior mod list:
JDM red STI engine ignition button
JDM dual console arm extension
JDM coin tray
Wrapped satin/flat red dash trim (Interestingly enough, the color turns out to be very close to Subaru's Cherry Blossom red)
Red trim cup and console liner
Interior and license plate LEDs
Blendmount and Mirror tap for Valentine One radar detector/Escort M1 dash cam
Perrin trunk handle
Subaru trunk cargo hooks (Require larger well nuts than supplied)
Discussion Starter #4
Installed JDM rear fog/brake light this afternoon. I know there are many options out there but 1) Don’t care for the F1 flashing function. 2) Want a clean install using OEM mounting points for the wire and entry into the trunk. 3) Don’t t want to have to change out the entire assembly should the LEDs malfunction or burns out. With OEM, you just need to replace the bulb. I held off doing this mod because I also didn’t want it to be on full brightness at all times. I re-visited this mod earlier this year when I saw SubiBros duel intensity harness and contacted DJ to see if it can be used with the JDM light, he explained that it is indeed a viable option if it is coupled with a proper LED bulb. He even offered to custom make a DI harness to uses the JDM plug-in. However, I ended up putting it off again as I was unable to find any information on how to mount the wire correctly. So I elected to purchase the S208/S209 front bezels instead. About 2 weeks ago, I stumbled onto an old thread on NASIOC with posts by steverx05 that was buried deep in the thread about the mounting points. And with that, I went back to visit SubiBros and much to my surprise, they now have a kit put together specifically for the JDM light. So I took advantage of the Black Friday sale to made the purchase. In conclusion, I want to say a huge “Thank you” to SubiBros and DJ and also, to acknowledge that I have some serious OCD issues when it comes to cars. Anyway, here are some photos I took this afternoon if anyone else also suffers the same illness as I do.
This is the inside of the bumper, you can see the 3 mounting points for the clips. However, I was unable to find the 4th mounting point anywhere. I think Subaru may have changed the bumper on 18+ cars. So I used some foam and wrapped up the 4th clip to prevent possible rattling inside the bumper.
57969
This shows the OEM entry point into the trunk (See arrow).
57970
From inside of the trunk.
57971
That red is such a good color. Looking great. Those front bezels really add to the aggressive look. I'm trying to decide between S4 w/ DRL and fogs, s209, or JDM w/ DRLs no fogs - your s209 look makes it very tempting. Looking forward to watching your progress.
Discussion Starter #8
Thank you.
Discussion Starter #12
Finally found a photo of the rear bumper cover with the 4th clip location is located. It is definitely not there on my car.
58797
Discussion Starter #15
Borla S-Type CBE. Readings were taken with an App by NIOSH (NIOSH Sound Level Meter App | NIOSH | CDC). About a foot behind the JDM 3rd parking light.
1) Cold Start in the garage
61799
2) At Idle, roughly the same location as above.
61800
3) Cold start, in cabin from the driver's seat.
61801
4) At idle, in cabin from the driver's seat.
61802
61805
I have this same exhaust on my 2019 STI. Love it & get compliments everywhere.
1 - 18 of 18 Posts
