2018 STI Limited
432 views 18 replies 9 participants last post by  xpystchrisx
Get the idoing unit from WRXdaily so that you will have a customer service source. I’ve had mine for two years and have no troubles at all. I run it with the factory upgrade Kickers and the OEM kicker sub in the trunk. Is it the best, no, but it does what I want. Looks good and sounds better than stock.
owns 2019 Subaru WRX STI Base FP Green Flex Fuel
Reactions: PSM_85
Just wait, dom 1.5 xtr, but then to run that on ethanol you'll need id1300s, which means a bigger in tank pump, which means an iwire hard wire kit, which means you'll need a better clutch, which means you'll need suspension, and the brakes... And then a new block, might as well do heads. And why'd you pick the dom 1.5? Should have gone rotated so you don't have that inefficient hot side. plus an exhaust manifold because efficiency.
This forum in one post. 😂
I can help someone spend their money with the best of’em!!
