Assuming that the STI is the same as an R-34 or an Evo: that's kinda short sighted.
What I'm saying is the same thing that the top suspension experts on this car, shops like TiC and RCE, will tell you. Cornering forces flex the front subframe at the strut towers by a minute amount because of the proximity of the strut towers to the firewall (unlike, for example, the R-34). Meanwhile, the same forces flex the soft rubber stock suspension bushings by much more, so that the flex in the subframe is completely negligible in the total amount of slop there is. Add to that the fact that all the braces (that only go between towers rather than tying to the firewall, unlike, for example, Mine's Evo brace) do very little to stiffen the subframe and have little leverage to do so and you have a situation where the strut tower brace doesn't do anything for you, no matter which one you pick.
Now... a front subframe brace, which ties together (and triangulates) the suspension mounting points much further forward (and away from the firewall): that's a modification that can be argued for, even on an otherwise stock STI.
