1 - 3 of 3 Posts
600awhp 2014 Subaru Impreza WRX STi in Dark Gray with 50k (Chassis/Drivetrain) miles for sale! 7k miles on the IAG Stage 3 Long Block, This freshly built STi is equipped with a ton of upgrades, including an ETS Rotated Turbo Kit, PTE 6266 Gen II BB, Visconti 525lph Fuel Basket Upgrade, P&L Triple Disc Clutch and much more! Professionally built by ShiftFast tuned by JrTuned! The car can be turned up with a bigger turbo and surge tank! Mileage will climb slowly as it's weekend driven. Recent oil change with Motul 300 V Power 5W40, trans/diff with Motul 300 Gear Oil. Clean title..
[email protected] for additional pictures
Contact me at +17049418609
Engine:
IAG Stage 3 tuff Long Block
Multi Angle IAG Valve Job
Resurfaced Heads
Kelford 220c Cams
Manley 33mm Exhaust Valves
Manley 37mm Race Flow Intake Valves
GSC Beehive Springs & Titanium Retainers
Cosworth 1.1mm Head Gasket
FHI Valve Cover Gasket
FHI Cam Seals
Case Halves, Converter to Closed Deck Using Brand New Subaru OEM Case Valves, Bored & H1d to 99.75mm
Machine Case to Fit 1/2" Head Studs
Manley Turbo Tuff 99.75mm Pistons
Manley Turbo Tuff I-Beam Rods
ACL Race Bearings
New Subaru Nitride Treated 17+ STI Crank
New Case/Main Bolts
Extreme .210 Wrist Pins
625+ ARP Rod Bolts
Perrin Crank Pulley
Killer Bee Oil Pan, Baffle & Pick Up Kit
IAG AOS Comp Series
Mishimoto Radiator Kit
Turbo System:
PTE 6266 Gen II BB
ETS Exhaust Manifold/Headers
ETS 4inch " Front Mount Kit big boy !!
Fuel System:
ID2000 Injectors
Aeromotive FPR
Visconti Subaru 525lph Fuel Basket Upgrade
Cobb flex fuel kit
Exhaust:
Invidia N1 Catback
Drivetrain: New updated 1600miles 7/24/20 fully broken in P&L Triple Disc Clutch w/ Street flywheel
Torque Solutions Trans & Motor Mounts
Wheels:
18x9.5 +38 ray gram lights 57dr
Stock wheels included
And a set of RPF1 18x9.5 +35 with front spacer for brembo clearance
tires: brand new tires = continental extreme contact dwo6 255/40/18.
Interior
AEM AFR, Oil Pressure & Boost Gauges
COBB Accessport V3 Flex Fuel Dated
Exterior: Wrapped Nardo grey
Dyno:
490awhp on 93 Octane
600awhp on E70 -85 % conservative tune
62178
62179
62180
62181
1 - 3 of 3 Posts
