161 - 180 of 893 Posts
Re: 2014 DGM Sti- *IAG*KillerB*
I like the min/max and the warning.
Would've come in handy for me more than once.
Discussion Starter #164
Yeah, I mostly am going with this because I only want one gauge that can read multiple things.
I should have the engine in the car this weekend... not sure if it will be crank ready. Still waiting on some kind break in tune for the TGV Deletes, header, and Air pump deletes.
Discussion Starter #166
I'm pretty sure the engine is going in on Saturday. Just a couple things to button up and it's good to go. OMG :eek:
Awesome. I like those gauges too, I really do not want a bank of gauges on the dash or A pillar. I love that you can have a default view but if it alarms for another sensor it will change views.
I've debated having an old rooted cell phone dedicated to a headunit that supports true screen mirroring. And then just leave it on torque basically. Use that for the stuff the ECU monitors, then have the PLX for stuff like oil temp, oil pressure, wideband o2, etc.
Discussion Starter #168
In the beginning I wasn't going to do much of anything to this car, so I never put a lot of thought into a gauge setup. I came from a car that was decently modified and wanted to take a step back to focus on becoming a real adult! :rofl::rofl:
Obviously that wasn't in the cards. But yeah, I had a triple on the A pillar for the last car and I just... meh. Simple is better now. Between the AP and the PLX I should be able to monitor everything I want that way. My buddy has the DM6 in one of his cars, and it seems to work pretty decent.
You could technically get the DM 100 (or 200) and run OBD-II monitors from that as well - so that's something to think about if you want to keep it minimal.
Buttoning it all up! :D
Aww look, such a little turbo, how cute.
Holy header will be going on today or tomorrow, and then should be dropping it in tomorrow. :eek:
Very noice. Agreed, there are some things I want to tweak but after having motorcycles with a fair amount of mods and having done many small mods to previous cars, I'm ready for more of an oem feel.
I just need to eventually find the time (and money) to get around to installing what I already have, and to finish building my car to its potential....however a new block and heads seem to be in the near future at this point.
Discussion Starter #171
YES! That's what I was hoping for as well - I was going to focus on suspension and just enjoying the car. I'll still enjoy it now, but it's not the same.
The feels are so real. I have things to install, suspension wise, and it just isn't going to happen. Brake lines - new pads - SS clutch line - random bushings. Hell I don't even know where the stuff is any more :lol:
What's the plans if you do end up swapping engines?
I'm true fashion I have changed my path again, going to put in a IAG closed deck with some moderate head work, a rotated setup and FMIC. No idea on what size rotated setup but as typical I change my path after I already have gone one way.
The 2.5 XTR is nice and I haven't even used the full potential due to the stock block but I already know I want more.
I too am a fan of multitasking gauges.
You should check out these ones from Innovate.
ECB-1 (BOOST) Ethanol Content & Air/Fuel Ratio Gauge
MTX Digital Series "Dual Function" Gauges
SCG-1 Solenoid Boost Controller Gauge
(good for non-ethanol setups)
And if you lookin for non-a pillar gauge pods, check out this from SMY
https://www.primesmy.com/gauge-pods-1541/smy-52mm-defroster-gauge-vent-pod-2008-2014-wrx-sti.html
Discussion Starter #174
I'm stuck on stock turbo for a little bit. :( Closed deck is the way to go for sure though, sometimes I wonder if I biffed. Time will tell. LOL
I was actually going to ask you about your vent gauge!!! Do you have any pics of it installed? I noticed you had it ready to go. It looks like a good execution, and it's out of the way but still visible.
Discussion Starter #175
Update:
Everything is ready to go. This morning I ordered a remote mount for the oil pressure sensor, and the last thing that the dealer didn't give me back, which was the coolant expansion tank on the driver side :mad::(:mad::mad::mad::mad::mad:
Thursday is the day now... maybe.
Discussion Starter #177
It's literally all in and ready to go. But the dealer that pulled the motor out didn't give me back some select items. So as I continue on I find out more that's missing. SOA will be getting a bill.
I don't think you biffed, unless you plan on going real big with the turbo.
I was pretty much all but sold on getting the closed deck, but went with the Stage 2 tuff
instead, as advised by Rick at IAG, Lachute Performance, and people on this forum (user).
Basically I was told it was overkill for my power goals, and that the closed deck would
not necessarily translate to longer engine lifespan. It was put to me as though I would have
been spending a lot more money on features that would never come into play. Lets hope
that holds true, because if the piston wall cracks in that one thin spot, I will be kicking
myself over not ignoring everyone and going with the closed deck.
Here are a couple pics of the gauge pod as requested :)
Discussion Starter #179
Image Link
Image Link
For the same reasons you did, I did as well. I'm really only looking for 450 WHP (if even that.) This is my daily driver :rofl::rofl:
THE POD LOOKS AWESOME! That makes that decision very easy, thankyou! LOL
ONLY 450WHP...lol...ridicoulous!
