41 - 60 of 893 Posts
Discussion Starter #42
Re: 2014 DGM Sti - Rocks in a can. :(
I'm using Scantool OBDlink. It works, but I'll most likely switch over to btSSM.
Can you hook up external sensors to that one as well? I'm mainly liking the ability to have one gauge face for multiple sensor inputs. I should be able to hook up 16 sensor inputs, and cycle through them when necessary.
Hey Joebie, just curious but were you at Stage 1 OTS when the engine blew?
Stage 2 OTS with no knock correction at WOT, and very minimal if any (1.4 and below in any other ranges). I did experience a lot, for one tank of gas, I believe that was a bad tank because on concurrent fillups, I didn't have the issue.
No. It's cool the PLX does this. I was looking into using PLX again, but I decided not to add more gauges in the car. Majority of my info is through my phone via OBDlink MX.
Debating between STG2 and STG3.. I like the idea of the tighter tolerances of the STG3 because I daily this car.
Also getting a list together on things I need to complete the swap in a weekend.
I'm planning on getting
  • OEM gasket set
  • Killer B oil pan/pickup/baffle
  • air pump block off plates
  • Oil pressure gauge setup of some sort
  • AOS of some sort - maybe IAG
  • fuel rail upgrade??
  • new oil pump? High volume?
  • ARP head studs
Things with question marks I'm debating, and/or not sure on at the moment.
Also debating doing the steering rack while the engine is out of the car, since I would imagine it's easier.
I'll be staying stock turbo, and headers/uppipe until I can at least complete break in (mostly because of my broken bank account after the short block and everything else).
Any insight would be awesome :)
I am currently going down the same road as you, so I can give you some insight for the build.
For the block, I went with the IAG stage 2 Tuff. That block is bored out to 99.75 for the tighter P/W clearance. Stage 3 is overkill unless you're trying to push into the 6-700whp range.
Go with the IAG AOS.
Don't worry about the fuel rails until you get a bigger turbo.
Do the clutch now! Trust me, I JUST put a new OEM one in 3000 miles ago but since the engine is out and I'm going with a bigger turbo I'm not going to wait for this one to start slipping.
IAG told me to go with the OEM 11mm oil pump, and I have a GD... they are building the block and know what clearances are going to be so I'll trust their decision.
The rest of the stuff looks good!
I'll also be doing the TGV deletes.
I'm going with the Dom 1.5xt-r, ELH, E85, 1100cc FIC injectors, blah blah all the bolt on stuff.
Do it right the first time. Good Luck!
Oh and don't forget to send your heads out the be cleaned and decked. You're going to need a new oil cooler if you did indeed spin a bearing too.
Discussion Starter #46
Thanks for the insight! It's funny because for some reason I always glossed over the STG 2 Tuff. I messaged User1029 and he said to do the H-Tuff rods, and I was already inquiring with IAG about doing the 99.75MM pistons, and then I realized I missed the 2-tuff. Oops!
I'll be ordering today .... I think. It's just hard to pull the trigger lol :lol: I'm waffling on the TGV deletes, mostly because of money, I do have phenolic spacers on the order though.
Discussion Starter #47
Yeah, I know what you mean. My old car had a triple on the pillar, and it was full, but I didn't want to be at that point again. The problem is, I already have a few toy cars - I just don't know when to say when. :rolleyes:
If I could get Oil pressure and true WB02 on the AP I would do that in a heart beat. So I may do a dual SMY cluster or maybe just a single on the pillar with the PLX gauge. I have some time to decide, I suppose. lol
I'm just going to gut mine stock ones. If you have a few tools available it costs nothing but a few bolts! Here's the how-to I'm using Meatys DIY TGV Delete Guide - NASIOC
Motor build funds are running dry for me too :lol:
Discussion Starter #50
Re: 2014 DGM Sti - Rocks in a can. :( - Stage 2 Tuff ordered
Finally got the dealer to call me back, they "confirmed" it was a rod knock. Not sure if they do an oil analysis, kind of hope they do, shit was brand new. >:-(
New parts ordered:
IAG Stage 2 Tuff block. I literally heard my credit card company yelling in excitement.
Too bad about the circumstances of ordering a new block;
I also went with the iag stage 2 tuff, to be installed in the next month or 2. So may i commend you on your excellent choice of blocks.
Here is to hoping the new block is better than your last :beer:
Discussion Starter #52
Seriously haha! :rofl:
How long did it take you to get yours, it looked like around a monthish?? Trying not to get too excited :lol:
Was really fast actually, took about 2 weeks to receive if I remember right.
I did, however, order it on black friday so IAG might have been in a 'ship everything crazy fast' mode.
Discussion Starter #55
I think, when the time comes, I will go with a spoolinator setup.
Nice choice of block. really can't go wrong with IAG, and their turnaround time seems to be real attractive as well. Probably what I would do if my engine goes outside of warranty.
They got quick turnarounds, because they have a bunch of blocks already done :lol:
Mines taken about almost 6 weeks now, but they are also doing the heads and assembly for me too. Its painful just waiting for it.
Discussion Starter #58 (Edited)
They literally shipped it yesterday and it's here tomorrow!!! :eek::eek::eek: :D:D:D
I debated headwork, but I don't have my heads currently. I'm also broke, so that helps deciding whether or not to do the heads. :rofl:
I'm waiting on SOA to either deny or confirm the warranties validity.
It's a very odd situation: They've confirmed it's a rod knock, so either a bent rod or a bearing. But the car was at full operating temperature and on new oil too. Car wasn't launched or redlined either. They are asking me to provide receipts on the filters, so I have to go through my statements and find as much as I can.
I'm starting to wonder if the oil pickup tube cracked or what actually happened.:confused:
Edit: Maybe an oil pump failure. Just weird.
weird situation. Hope SOA doesn't deny, but it's always a possibility. Every time I buy filters from my dealer I just buy like 6 since I am not at the dealer often. Put the receipt straight into my pouch containing owner's manual and maintenance manual, which is all in the glove compartment. I do the same when I purchase Rotella from Wal-Mart :D This way I have everything ready if something happens, at least.
Discussion Starter #60
Very *SMART* idea! I think a lot of my purchases were done online, so I can look back at order history - I hope :eek:
