1 - 3 of 3 Posts
I just bought a set of new wheels to OEM wheel spec not thinking about fitment issue and I hate how wheels are hiding in the fenders and I want to poke it out using spacers.
I've been looking at Perrin Hubcentric spacer, but for some reasons, a lot of online retailer (i.e., subispeed) recommends 20mm in the front and 15mm in the back.
Is it because rear will rub if I go with 20mm? If that is the case, can I just do 15mm all around? Or is that an issue for the front? My ride heigh and suspension is all stock.
I just hate how I would do 20mm in the front and 15mm in the back. At the same time, if you guys recommend any other brands who make hub centric spacers for 15mm or 20mm let me know please.
I know subispeed makes some and ISC? makes some. Too many brands out there.
Wheel spec of mine: Bolt pattern: 5x114.3 Centerbone: 56.1mm Wheel size: 18 x 8.5" Offset: +55mm Tire: 245/40R18
58725
stock suspension worked on my car. same specs. 20mm spacers. but as i lowered the car the rear rubbed on hard cornering. and im pretty high..
1 - 3 of 3 Posts
