1 - 20 of 87 Posts
Picked her up on 5/15/2013. I guess there are 99 more Special Edition STi's still out there :)
https://www.youtube.com/watch?v=gfuKRmz3hOg
Let the modding begin... 5/27/13 Looking for sponsors :)
** 6/2/2013 Added COBB SS Shifter. No biggie but it is my first Modd :) I wont bore you with the pics.
7/14/2013 WENT IN FOR UPGRADES AT IAG PERFORMANCE
*** UPDATES TO FOLLOW WHEN THE STi IS FINISHED BY IAG PERFORMANCE.***
I am taking the Plung. I purchased the 2013 Special Edition STi ... yes in bright orange.
The car is right now sitting at IAG Performance getting the biggest performance upgrade I could imagine.
**If anyone can build the ultimate Special Edition STi its IAG Performance.**
They have been super honest, knowledgeable, upfront , candid and I trust them with my money , time and car.
BUILD LIST... its long :)
Rotated Kit includes:
-IAG/GT Spec T304 Stainless Steel Header with V-band Connection
-IAG T304 Stainless Steel Custom V-Band Rotated Uppipe with Stainless Support Bracket -Garrett GT Series Turbo GTX3582
-Tial Stainless Steel Turbine housing (.68 A/R, .82 A/R, 1.01 A/R)
-IAG Custom 3” T304 Stainless Steel V-Band Rotated Downpipe
-Stainless Steel Braided Oil Feed Line
-Aeroquip AQP Oil Drain Line with Billet Flange
-Billet Banjo Water Line fittings and hose.
-Stainless Steel Power Steering Line
-IAG Catch Can Kit with all Fittings and Lines OR Crawford AOS
-Tial Sport Q Series Blow Off Valve
-Tial Sport 44mm V-Band Wastegate
-IAG Custom T304 Stainless Steel Dump Tube
-IAG Custom Rotated 3” or 4" Alumimum Draw pipe
-K&N 3” Hi-flow Air filter
-Manifold Gaskets
-Downpipe Gasket
-All Zinc Plated Hardware
-- Process West Intake Manifold <<<< WOW!
Tuning Mod List:
Engine: IAG Built 2.5L w/ Stage V Heads & 220C Kelford Management: Cobb AP V2 Speed Density
Turbo: IAG Rotated GTX35R
Exhaust: 3" Catless DP to Invidia N1
Injectors: ID2000cc Top Feed
Intake: IAG BigIntake (w/ Rotated Kit)
Spark Plugs: NGK 1-Step Colder
Intercooler: IAG BigCore FMIC
Boost Control: Grimmspeed EBCS
Fuel Pump: Aeromotive 340lph
Other: IAG Headers/44mm EWG / Airpump Delete / TGV Delete /
**** SOME PART NUMBERS IF YOU WANT THEM
Protuning Speed Density by Jorge, hosted by IAG Performance
612002C-4 - MANLEY PLATINUM SERIES PISTON SET STI
14024-4 - MANLEY STEEL H BEAM CONNECTING ROD SET << changed to the Tough version
5M8309H-STD - ACL RACE MAIN BEARING SET SUBARU
4B8296HX-STD - ACL RACE ROD BEARING SET SUBARU
EJ20/EJ22/EJ25 52mm Journal w/ Extra Oil Clearance
Use Existing Heat Treated STI Crankshaft
800210990 - FHI ENGINE CASE BOLT
800610010 - FHI ENGINE CASE BOLT
004403007 - FHI ENGINE CASE SEALANT
10105AB200 - FHI ENGINE GASKET KIT STI 08
T328RB - GATES RACING TIMING BELT SUBARU WRX 02- LGT 05-09, FXT 04-08
260-4701 - ARP HEAD STUD KIT SUBARU EJ 2.OL, 2.2L,
IAG Performance Billet TGV Delete / Fuel Rail / Line / Fitting /
2000.18.02.48.11.4 - Injector Dynamics ID2000 top feed injector set WRX 02-11 & STi 07-11/ Turbo 2.0L & 2.5L
IAG-ENG-3001SL - IAG CNC TOP FEED TGV DELETES
IAG-ENG-2102SL - IAG BILLET ALUMINUM TOP FEED FUEL RAILS W/ LINES + FITTINGS FOR 2002+ WRX, 07+ STI, 08+
LGT SILVER CLEAR ANODIZED
13109 - AEROMOTIVE A1000-6 FPR FUEL PRESSURE
REGULATOR
8177 - PDP MOTOR OIL 5W-30
11497 - ROYAL PURPLE BREAK-IN ENGINE OIL
PL14460 - PUROLATOR PUREONE OIL FILTER SUBRAU 02 -05 WRX, 04-09 STI
GLOBAL COOLANT - GLOBAL COOLANT
Bore Block to 99.75
Motor Labor - R&R Motor, build & blueprint, reinstall back to running
IAG Stage V Head Package - Includes Port work, +1 valves, springs, retainers
11140-8 - MANLEY RACE FLO VALVES SET 37MM INTAKE WRX/STI (8)
11139-8 - MANLEY EXTREME DUTY VALVES SET 33MM EXHAUST WRX/STI (8)
26180 - MANLEY VALVE SPRING AND RETAINER KIT WRX/STI (22180,23180)
220-D - KELFORD 280/276 degree, 11.5/10.7mm Lift Race / Built Engine Cams 08-11 STI
IAG Performance Rotated Turbo Kit w/ GTX35R (see kit contents at top of page)
IAG Performance BigCore FMIC Kit w/ Chromoly Bumper Beam
MMRAD-STI-08 - MISHIMOTO ALUMINUM RADIATOR WRX/STI 08+
MMHOSE-STI-08BK - MISHIMOTO RADIATOR HOSE KIT WRX/STI 08+ (BLACK)
Install FMIC Kit & Rotated Kit (including bumper modification, etc.)
Speed Density Kit & Setup (includes IAT Sensor, fabrication, etc.)
057007 - GRIMMSPEED Subaru Boost Solenoid 08+STi
15030-1620 Competition Stage 4 Sprung Puck Clutch Resurface Flywheel
11142 - AEROMOTIVE FUEL PUMP 340 LPH SUBARU Install Fuel Pump
30-2130-50 - AEM 3.5 BAR MAP SENSOR KIT
SUB-00021 - Cobb MAP Sensor Adapter Harness all 2.0 or 2.5 Turbo WRX/STI/FXT excluding Legacy
IAG-ENG-2050 - IAG AIR PUMP BLOCK OFF PLATES FOR 06+ WRX, 07+ STI, 06+ LGT (PAIR)
LFR7AIX (2309) - NGK SPARK PLUG IRIDIUM IX 2309 One Step Colder WRX/STI 2.5L
09-07-3013: Picked the car up from IAG Performance
Named the car CRUSH
Welcome!
There is a pretty good thread on getting sponsors if your serious about that.
Butt posted from my Galaxy Note II
Make sure you take care of the paint. Subaru paint is notoriously shitty. You may want to look into clear bra on the hood, bumper, and fenders. I could care less about my paint because I'll probably end up repainting the car, but this paint should help your car hold its value well
Discussion Starter #8
I hear ya. I will definitely be looking into getting the clear bra this weekend.
Definitely serious about it!
everyone always is, when they are in the mind set that they are getting amazing discounts and free parts for next to nothing..
definitely look up the sponsorship faq thread to find out what it really entails. the majority of the time, it's a lot more work and the pricing isn't nearly as hot as people thought it would be.
i wish orange was available in my year. looks good :tup:
i did my clearbra for around the same price. avery w/ lifetime warantee.
included the following:
front bumper, front fender + hood up to about 24inches, side mirrors, gas cap, replaced stock clear bra on rear fenders, and the trunk sil.
i might also recommend doing the rear bumper so if for whatever reason one day if someone bumps you, it'll help protect it from minor stuffs.
Discussion Starter #19
I agree with that for the most part however , attitude and being creative go a long way. So does having a realistic approach.
1 - 20 of 87 Posts
