1 - 12 of 12 Posts
If Parts are listed they're still available. Prices are pretty firm but will consider offers.
2013 GR STI with 68k miles on the chassis and 12k on the new motor. I had the engine built last year and did all the supporting mods throughout my ownership of the car from new in '13. I planned to upgrade the turbo and inter-cooler this spring but a deer foiled those plans. Will update with pictures as I take the car apart. Located in Newtown, CT and prefer local pickup but may consider shipping smaller items at buyer's expense.
Interior
A pillars (alcantera) with 2x guage pods 150 SOLD
center cluster (alcantera) with 2x guage pods 175 SOLD
visors x2 (alcantera) 100 SOLD
Dashboard (alcantera) 500 Pending
Center Console w/ drive mode selection (black alcantera) 200 SOLD
Dual stock radiator fans with overflow tank 75
Headliner (black suede) 250
Shift boot (black alcantera red stitching) 50 SOLD
Parking Brake Boot with mounting frame(black alcantera red stitching) 60 SOLD
Shifter surround (alcantera) 150 SOLD
Stock leather wrapped steering wheel 75
Front and rear seats 850
stock b-pillar covers 20
dome light 10
window motors and mechanics 100
door handles w/ window switches x4--set 150
Subaru all weather floor mats (front and rear) 50
Weather Tech Floor liner (front, rear, trunk) 170
High Quality Sun Shade Eyes by artisticreflection.com/eyeshades 70 SOLD
2x side cargo nets and 1x rear cargo net 40 SOLD
Stock Shift nob 35
Weighted shift nob 40 SOLD
Stock floor mats 2x front 2x rear 35
Stock steering wheel airbag 200
Front Door Cards 100 Pending
Rear Door Cards 100
Interior Pictures: Flickr
Gauges/ Sensors
Cobb access port v2 225
AEM Wide band 02 gauge with sensor 80
Defi Boost Gauge 100
Defi Temp Gauge (oil or water) 2 available 75
New (never installed) 52mm Prosport Air/ Fuel Ratio Gauge Kit w/ 0-5V analog output 120 Sold
New (never installed) 52mm Prosport Oil Pressure Gauge 35 Sold
New (never installed) 52mm Prosport Oil Temperature Gauge 35 Sold
New (never installed) 52mm Prosport Boost Gauge 35 Sold
Escort 9500ci integrated autodimming rear view mirror and laser shifters 1200
Flickr
Exterior
GrillCraft Front Upper Grill Black (mesh grill only) 30
Flickr
Motor, Trans, Diff, Brembos, Exhaust, Radiator
Built engine from Larry's Power in Groton CT with 12k miles. (CP pistons set 99.75mm Bore 8.2:1 CR, Manley rods, competition multi angle valve job (pair), set valve lash, solid pucks, resurface heads (pair), manley valve springs, mic crankshaft and clean, check main bores, square block deck on rottler CNC (with bore and hone), CNC bore and hone block w/ torque plate, final wash block, file fit rings, check engine bearing clearances, modify oiling system/ grind and modify passages, computer balance assembly (pistons, pins, rods, and crankshaft), install valve guides, fit valve guides, king main and rod bearings, BR-30 break in oil, Gates racing timing belt kit w/ water pump, full gasket and seal kit, ARP head stud kit 11mm, Killer B oil pan package, Cosworth High Volume/ Pressure Oil Pump kit, Air pump delete plates, NGK Iridum Spark Plugs One Step Colder, Grimmspeed lightweight crank pully, ACT Pilot Bearing, Exedy Release Bearing, Exedy Stage 1 Heavy Duty Organic Disc Clutch, ACT Streetlight Flywheel).
Running motor video: GR STi Part Out - YouTube
Pictures of the build: Flickr
5300
Trans, brakes, radiator, exhaust
Transmission, rear diff, drive shaft 4000
brembo brake set, DBA Rotors and Hawk Pads, 5x114 hubs 2600
Killer B 4-1 Holy Header 700
Invidia Downpipe Catted Divorced Wastegate 300 Sold
Invidia Q300 Cat Back Exhaust 500
Mishimotor Performance Aluminum Radiator and Hose kit 200 Sold
Beatrush Engine Mounts 150
Cobb Short throw shifter 100
https://www.flickr.com/gp/[email protected]/x7Xv69
Stock Exhaust
Stock Cat Back exhaust 200
Stock Exhaust Manifold 100
Stock up pipe 50
Stock down pipe 125 Sold
Photos here: Flickr
Ancillary
Front and Rear Shifter bushings 25
Stock Transmission Mount 30
Stock Pitch stop mount 35
Stock sway bars 110
Stock Intercooler w/ Y-pipe 225
wheel locks 25
turbo inlet 100 Sold
stock turbo 300
stock injectors 150
Perrin fuel rails w/ pyroshield lines and ID 1000cc injectors 600 Sold
stock MAF sensor 75
Deatsch Werks 265 LPH compact in-tank fuel pump 75
PTP turbo blanket 50
Moroso Catch can with mounting bracket 50 Sold
https://www.flickr.com/gp/[email protected]/H81ZDD
Wheels/ Tires
stock GR STi wheels 18x8.5" offset +55, 5x114.3, powder coated gold, with summer tires (245 40R18 Dunlop SP Sport 600) with minimum tread remaining, and TPMS sensors, (see pics for curb rash that has been touched up with paint, priced accordingly) 800 Sold
Flickr
Previous Gen BBS Wheels powerder coated gold x3 300
Blizzak WS 80 tires (225 50R17) almost brand new 200
1 - 12 of 12 Posts
