1 - 5 of 5 Posts
For sale my 13 sti sedan, dgm with wingless trunk. Clean title in hand. I’m the original owner and have done all the work at either Subiworx in Tempe AZ, RA worx in Phoenix, dynocomp in Scottsdale or snail performance in Phoenix. Currently running on a 91 octane tune but comes with an e54 tune that makes more power etc. Below is the list of everything that’s been done to it. The car is ready to handle whatever. I have most of the stock parts so if you’d like to go back to stock that’s an option. Currently has 83,000 miles. Never had pets inside or been smoked in. Paint is in great shape minus rock chips in the front. There’s a lot I’m forgetting so if you have any questions feel free to ask. Also just text or call me, thats the best way to get in contact, 480-862-4343. Asking 20,000 but feel free to make me a fair offer
Moroso dual catch can
Beat rush pitch stop
Aeromotive fpr
1300cc id injectors
Cosworth rails
TGV deletes
DW fuel pump
Process west tmic
Built block by RA worx that burns no oil
Csf radiator with oil cooler
Hella supertones
Injen intake
Grimmspeed ebc
Secondary air pump delete
Group n motor mounts
Killer b oil pickup
Killer b larger pan
Killer b Windage tray
Gates timing belt
Stainless steel lines
Dba rotors
Defi boost gauge and oil pressure gauges 60mm
JCS Pillar pod
Cobb AP with e54 and 91 tunes from snail
Super pro front and rear sway bars
Super pro endlinks
Super pro bushings
RCE yellows
Cusco rear lower control arms
Invidia catted dp swain tech white lightning coated
Corsa cat back exhaust black
Turn in concepts tall boy short shifter
Latheworks titanium shift knob
Kartboy shifter bushings front and rear
RA mudflaps
Silicon upper and lower radiator hoses
15 sti steering rack
Grimmspeed up pipe
Ptp turbo blanket
Act stage 2 clutch
Perrin reverse ring lockout
Discussion Starter #2
Bump Bump
Comes with tons of paperwork for maintenance, parts, engine build. Also and AZ car so absolutely no rust!!
1 - 5 of 5 Posts
