221 - 225 of 225 Posts
Discussion Starter #221
Small updates
Car was running pretty lean in boost, way off target AFR
Decided to do some troubleshooting, thinking maybe my fuel filter not being changed in awhile was causing a drop in fuel pressure. So i swapped that out
it was a little dirty, but not horrible. It didn't seem to help, as I was still running lean. Next up was a boost leak test, and sure enough I had a pretty massive leak at the FPR nipple
Not sure how it got loose, but the hose clamp was way too loose. It only seemed to hiss above 15 psi, but at 30 psi it was quite a leak.
Discussion Starter #223
Finally figured out my lean issue.
Turns out, my Walbro 450 started to go bad. It could not keep up with fueling demands at high boost. I swapped it out for another one, and problem solved
Discussion Starter #225
Been awhile since I posted, lots changed!
I picked up a killer-B oil pan so I could wire in an oil temp sensor and add oil capacity for track racing, and bought a new house!
58687
Now I have a bigger garage and more space for hoodrat car things
