1 - 5 of 5 Posts
**SOLD**
I'll set this out there for my 2012 STI Hatch. Fully built forged engine, supporting mods.
Currently makes 443whp and 417wtq on e85. Flex fuel. Just over 40,000 miles on the car, and 9k on the engine and turbo kit. Well sorted out car, and built to take up to 650whp. Located in Houston currently. Buyer is responsible for delivery of vehicle. Clean Texas title in hand. Never tracked, only weekend driven mostly since 2013.
Interior 9.5/10 - Never smoked in, has almost no wear anywhere
Exterior 8/10 - Great shape, some small dents and imperfections
Engine Built from all new parts
Outfront Motorsports V3 Closed Deck
JE 99.75 Pistons
Manley "Turbo Tuff" I-Beam Rods
King XPG Bearings
Killer B Oil Pick-up and Baffle
HKS Timing Belt
Tomei Timing Belt Guide
Fluidampr Crank Pulley
OEM Dual AVCS (W25) Heads
OEM STI Cams
GSC Beehive Valve Springs
OEM STI Valves
ARP L19 Head studs
Cobb Plano Pro-Tuned
Cobb flex fuel, with fuel pressure. Speed density.
Turbo Kit
Kamak Twinscroll 25GTX TD-06 SL2
Tomei Twinscroll header/up-pipe
Tomei Twinscroll catless downpipe
ETS FMIC
Tial Q BOV
AMR 3" Hard Inlet
AEM Intake (Modified) w/ K&N Filte
Fuel
Radium dual pump hanger, with walbro 450
ID1300 injectors
Radium Fuel Filter
AEM FPR
Other
TGV Deletes (Composite)
Air Pump Delete
Blitz Nur-Spec R Catback (with custom axle back)
CSF Competition spec Radiator
Crawford AOS
AEM 3.5 Bar Map Sensor
GM Delphi IAT 25036751
Suspension & wheels/tires
RCE GT Worx Bilstein Struts
RCE Yellow springs
Cobb sway bars
All whiteline bushings
OEM BBS Wheels, black - Michelin Pilot Supersports 245/40/18
SS brake lines
EBC yellowstuff pads
Cusco front, lateral, and steering rack braces
Drivetrain
Cobb short shifter
Perrin reverse lockout
DSS carbon fiber driveshaft
GT Spec D shaped carbon wheel
Carbon fiber shifter and av panel
JPM shifter and handbrake boots
Pioneer AVIC head unit with GPS
Valenti all LED tail lights
Blacked out headlights
CS front lip, skirts, rear spats
Front 1/3 of car is clear bra, along with other areas.
There is quite a list of other parts/mods to the car that I will be gathering as I remember.
More pictures available on request.
1 - 5 of 5 Posts
