1 - 20 of 25 Posts
Re: 2011 wrb sedan + invidia q300 ss tips
How difficult was the install? I have my eye on that set up. You go with the invidia DP also?
Here is a question that has not been answered yet about this exhaust: how much play is there from left to right on the exhaust? Namely because I don't want a melted bumper while I am racing on the track and the cans are melted onto the bumper.
Creeper v.02
This exhaust is perfect. Beautiful. Perfect in every way!
Looks really good! I'm thinking about picking this up for my 2011.
Hows the sound while cruising? Is there any drone? It is a good amount louder with stock, even with the stock DP?
Thanks.
Really simple, I used an impact gun and ramps so the stock system was off in about 10 mins and the new one was on in about 40mins total. Only issue I had was connecting it to the stock dp because the gasket they give doesn't seal it properly. No matter what I did it leaked very little. I got an additional gasket and doubled it up and no exhaust leaks at all now. And lining up the tailpipes equally was semi-tricky you just have to play with it. And as for the invidia dp I wish I bought that too, later on down the road definitely. Sounds awesome the way it is.
When yours leaked, did it make a air rushing like sound only at boost?
Mine is doing that and I got a much thicker gasket, but its still doing it. What gaskets did you get?
Thanks!
If you're worried about the exhaust swaying from side to side, you could always purchase urethane exhaust bushings from either Cobb/ Kartboy.
1 - 20 of 25 Posts
