2008 STi engine install - need help with a couple harness connectors & evap system
5927 Views 6 Replies 3 Participants Last post by  Zzyzx85
I have a few connectors from the engine harness that I'm unsure of.
This connector is near the throttle body, but I can't figure out what it connects to...
These two connectors are identical, both fit the evap assmebly, but there's only room for one and all nearby sensors are connected...
I also have a question about what I believe is part of the evap system and how it all connects.
Not quite sure how this all comes together, should have taken more pics before removing...
1 - 7 of 7 Posts
Re: 2008 STi engine install - need help with a couple harness connectors & evap syste
the one in the top picture looks like it goes to a air pump valve. if you have done an airpump delete maybe thats why it is missing? i believe this one is disconnected on mine as well and i have the air pump hardware removed. i just tore mine completely apart to install pistons a month ago. my advice for next time is paint marker label every connection with a letter and same with hoses connections.
in the second are the two connectors different colors? if they are grey and black the picture i have of mine show the black one going to the connection with the hoses from picture 3.
in the 3rd picture the hose that is loose with the ? goes to the bottom of the 2 ports shown. the top port goes to a tee fitting. i cant see where the intake line terminates and dont remember off the top of my head
I thought it was for the pump hardware, but I pulled the pump and valve out of the bin in the garage and didn't see one that matched up.
They're both identical connectors, both black and 2-pin.
Thanks, hopefully someone can chime in with more details.
Also, is there a good way to tell if I have the injector wires connected to the correct injectors?
honestly the only other thing i can think of in that area is the knock sensor. it mounts directly below the bypass valve under the intake. the injector wires i think are somewhat different lengths. i just got back from 2 days worth of racing so maybe ill go outside tomorrow in the daylight and take a look at mine and see if i can help you out any better.
i just posted in your thread on SCS about the solenoid connections.
injector wires: yes, spud has it right. The connectors lead to each injector. if your wiring harness is in the right location, there's no way to incorrectly connect them.
Picture 1: it's one of these:
knock sensor, light gray, 2 pin
MAP sensor, black, 3 pin
secondary air combination valve, black, 2 pin
it looks gray and has 2 pins in the photo, so i'm guessing knock sensor.
Image Link
Nice, thanks! :)
I'm going to have to find the #1 in that pic, where is it typically located?
I believe solenoid #1 is under the intake manifold. I don't quite remember from the last time I took off the intake manifold but that was something I didn't touch for the intake manifold removal iirc.
1 - 7 of 7 Posts
