1 - 8 of 8 Posts
Vendor
Coilovers are finally available for the 2008 Impreza and STi Models!
CUSCO Zero2-E
With all the same benefits and features as the Zero-2 coilover, the Zero-2E adds the option to electronically control the shock adjustment from inside the car. Utilizing the E-Con (sold separately), you can select what stage (of 5) you want the shock set at. With great features such as:
- Electronically controlled shock adjustment (w/ E-Con)
- Pillowball upper mounts
- Adjustable shock casing
- Independent adjustable spring perch
- Stainless steel thread body
- Stainless steel case lock nut
- Stainless steel spring perch/lock nut
- Specially coated lower bracket
Fits perfectly for any style driving. The advanced design features 5-stages of shock adjustment that exhibits incredible performance!
Create a comfortable ride for your passengers. Too stiff? Comfort is just a button away. No more frustrated passengers!
Larger size pillowball used in the upper mounts. Endures through the hardest drives!
Height adjustment and spring pre-load are designed to be adjusted independently. Lower your car with the adjustable shock casing while retaining the overall shock stroke. Set the spring pre-load to your desire and feel the difference in driving and traction.
Cusco developed a new shock absorber for the Zero-2E that further reduces friction resistance of the dampening force to achieve high performance with the vehicle lowered.
New design: Side port rotary valve
New: Reduced friction piston
New oil reducing cavitation
New material: Special steel for piston valve shim
Worried about rust? No problem with the Zero-2E’s stainless steel lock nuts, lower seat, and threads. With the external cylinder and threads being stainless steel, adjusting the height will be smooth. The lower bracket/case has a new special coating as well. The internal as well as the external surface has been coated.
Stock Front Vs Cusco
Stock Rear vs Cusco
Before
After
IN STOCK READY TO SHIP!
WRX1,988.80 Shipped
STi 2,042.50 Shipped
Type OS Front Strut Bar! 159.60 Plus Shipping
WRX and STi
The most popular of the Cusco bars is the Type OS. The classic design features a tubular aluminum oval shaft with a high polish finish. The end plates are painted the traditional Cusco blue and come with all the required hardware for installation. It bolts on in minutes using normal hand tools.
Please Call or Visit the link below to Order! ALL ITEMS IN STOCK READY TO SHIP!
LINK TO ITEMS
Thanks
Kirill
RallySportDirect.com
801-748-4910 ext 1006
HOW TO WRITE UP
1 - 8 of 8 Posts
