1 - 20 of 33 Posts
Banned
Numbers
Dyno: Dyno Dynamics
Tuner: Auto Master AMR
Wheel HP: 350whp (stock 201whp)
Wheel TQ: 360wtq (stock 225wtq)
Car Info: LINK TO JOURNAL
Year: 2008
Engine Management: AMR PROTune (COBB APv2.0)
Turbo: AMR T50R w/ Optional Custom Actuator
Intercooler: AMR Top Mount Intercooler (TMIC)
Meth Kit: NONE
Injectors: AMR 750cc Injectors
Intake/Inlet: AMR BMI Cold Air System
Headers: STOCK
Uppipe: STOCK
Downpipe: AMR Downpipe
CBE: AMR Dual Exhaust System
Other Power Mods:
- AMR EBCS
DYNO SHEET:
Notes:
I am very impressed with this combination. We achieved full boost (22psi) at 3500-3600rpm. AFR's were 10.5 (really conservative). Timing left on the really low conservative side (which you can see from the TQ). This turbocharger really starts to shine over 19psi. The vehicle hits a hard 360wtq by 4000rpm and pulls extremely hard straight to 7000rpm. Definitely fun to drive. I took the car for a 1 hour drive last night to visit my parents, all you heard was the whistling of boost even at 1/4 throttle. The reason we all purchase a turbo car
. I tried to see if there was any vehicles (Porsche, etc.) to kind of play with but no dice. When I get sometime I will take this beast to the track and get some track results for you guys as always.
Power Increase: +150whp over stock (safe & conservative)
Tuning Note:
- AFR: 10.5
- BOOST: 22psi
- TIMING: Conservative
- FUEL: 93 Octane
-Rob
Re: 2008 STi - 350whp / 360wtq
How much did the AMR TMIC cost? I'm not familiar with the new 08 models, but where is the BPV. It looks like its usual flange is closed off.
Banned
Discussion Starter #4
The AMR TMIC is $899. What you see were the BPV or BOV sits is just a "BLOCK OFF" Plate we fabricated for testing. It is just bolted on. The flange is still on the TMIC for any BOV to fit. :tup:
-Rob
That dyno plot is very impressive. Same power/spool as stock from 3400rpm and below, and tons more power after 3500rpm all the way to redline.
I was looking at 20g or atp 3071 for a turbo upgrade, but this turbo has me thinking more.
Any plans on running a header and uppipe? I have been waiting for the maddad equal length header to come out.
Re: 2008 STi - 350whp/360wtq
Extremely impressive gains for the mods done!!! And considering the conservative nature of the tune, I'm sure there's at least another 20-30 in there safely.
Keep up the good work.
Take this thing to the track yet?
How much is the turboback? on your website it still says $999,999.99...seems a tad bit pricey to me...
Banned
Discussion Starter #12
I figured the $999,999.99 was pretty fair. If you order now I can give it to you for $999,998.99. :rofl: j/k
Pricing and Availablity will be released next week!!!!
-Rob
Banned
Discussion Starter #13
Here are some engine bay and product shots!​
Also, PRE-ORDER your AMR DUAL TURBO BACK EXHAUST SYSTEM TODAY!!
-Rob
Banned
Discussion Starter #15
What you all have been waiting for!
Vehicle:
- 2008 Subaru STi
Modifications:
- AMR Top Mount Intercooler (TMIC) w/ AMR Breather Kit
- AMR BMI Cold Air System
- AMR Dual Turbo Back Exhaust
- AMR T50R Bolt-On Turbocharger w/ Optional Upgraded Actuator
- AMR 750cc Top-Feed Injectors
- AMR Electronic Boost Control Solenoid
- AMR PROTune Map (COBB APv2)
Time Slip:
Thoughts:
On a personal note, I am extremely excited to finally pull off the 1.6 60ft. I have been pretty consistant with the 1.8's. But to finally hit a 1.6 is a personal achievement. As you can all see the 115.89mph in a 1/4 matches the 356whp the vehicle layed down on our dyno. The vehicle weighs 3548lbs with me in it along with some extra's in the back (daily driver). E.T. is excellent due to the perfect shifting and all. This is definitely a near perfect pass. The 2008 STi is more and more promising every time out!
Dyno Sheet:
Link: 2008 STI - 350whp/360wtq
-Rob
Wow!! Great numbers and great time.
What size inlet did you use?
Keep up the great work over there guys!
Banned
Discussion Starter #18
What kind of timing were you running at peak torque and redline? I'm gauging your version of conservative :D
Looks great btw.
Banned
Discussion Starter #20
Looks great btw.
Conservative, to me, on the timing, is 9*-11* at peak and 18*-21* at redline.
Thank You
-Rob
1 - 20 of 33 Posts
