1 - 12 of 12 Posts
I don't know if this is the best place to ask this, but I'm thinking of selling my STi and I'd like to get some opinions on what it might be worth. It's one of those cases of "I don't want the car anymore, but if the sale price is low I'd rather keep it."
Can anybody help me price this? Here's everything I can remember that's been done:
Rebuilt rear after collision
Added SPT Rally Blue battery hold down
Hardwired Valentine V1 with stealth display in instrument cluster
Silvered the red STi's on the sides
BBS wheels from subaru and spare enkei wheels
Hella Supertones
Rally Armor Urethane Mudflaps
Blue "i" Badges front and rear
All-Weather Floor Mats
Subaru Group N Lateral Link Bushings
Subaru Group N Crossmember Bushing Kit
Subaru Group N Trailing Link Bushings
Subaru Group N Pitch Stop
Subaru Group N engine mounts
Subaru Group N transmission mounts ?
Subframe positive traction kit inserts
Differential positive power kit
lower control arm bushing kit
trailing link bushings
front and rear lateral link bushings
Goodridge braided steel brake lines
Goodridge braided steel clutch line
kartboy endlinks
Motul differential oil
Setting Saver
SPT Short Shifter
Kartboy Front and Rear Shifter Bushings
LatheWerks Burnt Titanium Shift Knob
2011 STi front control arms with pillowball bushings
Torque Solutions solid metal shifter linkage U-joint
ACT Xtreme Duty performance street disc clutch kit (model #ACTSB10-XTSS)
IAG Stage 2 2.5L Engine:
99.5mm Stock Bore
Manley Platinum Forged Pistons, Ringset, .210” Steel Pins, Clips, Coated skirts and offset Wrist Pins
IAG-Spec H-Beam Rods
ARP2000 rod bolts
King Race Main Bearings? (could be ACL)
King Race Rod Bearings? (could be ACL)
Subaru Nitride Treated 2017 STi Crankshaft
Compression Ratio 8.2:1
aFe Direct Fit Magnum Pro Dry S Performance Air Filter
Part Number: AFE 31-10161
FlexInnovations grounding wire kit
Injector Dynamics Fuel Injectors Top Feed 1000cc
Part Number: IND 1000.48.11.WRX.4
Aeromotive Top Feed Fuel Rail System
Part Number: AER 14135
DeatschWerks (9-652-1008) 265 LPH Compact Fuel Pump with Installation Kit
GrimmSpeed Master Cylinder Brace
Part Number: GRM 091029
GrimmSpeed Boost Solenoid
Part Number: GRM 057007
Killer B Motorsport Ultimate Oil Pickup
Part Number: KIL 070-110
Nameless Performance Air Pump Delete Plates Blue
Part Number: NAM RSPD020
Gates Timing Belt Kit w/ Water Pump
Part Number: GAT TCKWP328
E85 flexfuel tune performed at AWDTuning in Flower Mound, TX (389 HP)
Maddad Whisper Catback
Maddad V2 downpipe
Blouch Dominator 1.5XT-R 8cm^2 Ceramic Coated Turbo
Killer B Motorsport Oil Baffle Windage Tray (#EJWT)
Kartboy 12mm Exhaust Hangers (#KB-011-12mm)
ARP2000 11mm Head Stud Kit (260-4701)
SuperPro Sway bars
Subaru OEM Engine Gasket and Seal Kit (#10105AB200)
H3R Performance Halon Fire Extinguisher
Universal Fire Extinguisher Bracket
There may be more stuff I can't think of.
See about
Deleteed
Doc, no offense but you have 1,715 Posts on this forum. Pick a price you want to sell the car for. Simple as that. Lastly, post pictures and location.
Discussion Starter · #4 ·
The point is, I have no idea what it might sell for. If someone wants me to put a price on it, I say $100,000.99.
I think most people would say it's worth less. I want to know what the experts (people on this forum) think I might be able to sell it for.
Is my number of posts on this group too much? I'm willing to accept expert opinions on that too...
Edit: KBB says it is worth $9000. To me that seems a little low...
Did I mention slap this bad girl can fit so many mods in it?
So, correct me if I'm wrong
Rebuilt title? Salvage title? you said "rebuilt after rear end collision"
How many miles on chassis?
How many miles on engine?
Okay, how is $7000 ?
This was my next question. Salvage title? Rebuilt title?
Pics
Discussion Starter · #8 ·
No salvage. Maybe I should have said repaired after collision.
About 120000 on odometer, 40000 on engine.
In this market I'd say 18 to 20k if the body is in good shape.
I sold my wife's 2011 wrx premium sedan with 86k miles, stage 1 mods and about 6/10 body for 14000.
Discussion Starter · #10 ·
Thanks. That's the sort of info I need so I can get an idea what price I should put on it, or even if it is worth selling.
np
You wont get the money back for the mods. You'd ideally be better off demodding, putting back to stock as much as you can and then selling the mods as well as the car. but I know that is a lot of work
Discussion Starter · #12 ·
np
Yeeesh! I don't wanna do that!
this may end up a weekend car...
1 - 12 of 12 Posts
