1 - 2 of 2 Posts
Long story short I bought a used 2007 sti, it broke down surprise surprise.
I bought a used engine online an ej255 2.5 imported from Japan out of a 2004-2007 sti Forester
Took It to the shop to do the swap guy tells me it's not a direct swap as I was told
The main problem is the EGR pipe is incapable can I swap the motor without the EGR.
What are the risks?
not passing smog...you would need custom tune to remove EGR system...you can swap over the externals as it should all bolt up...
1 - 2 of 2 Posts
