1 - 12 of 12 Posts
Hey everybody,
Just a quick question...I have a full tbe, injen cold air intake, blitz boost controller, ported wastegate, and a tune. Does anybody else have mods done like this to their sti and if so what horsepower and torque gains are you getting on a dyno?? I got 300 awhp and 331 ft. lbs of torque. Should this be higher or lower, or am I sitting ok? Thanks a lot everyone.
ur fine
thats very respectable with the items you have...:tup:
With what I have done, what should be my next mod for the best horsepower? Thanks again for the replies.
Keep in mind that raw numbers from a dyno mean nothing. There is no way anyone can state for sure that is where you should be because each dyno is different. Even the same dyno is different day-to-day. Did you run a baseline on this dyno?? The change is what you need to look at not the end result.
Turbo Inlet pipe , Headers, or Turbo
See my sig. You're right on.
1 - 12 of 12 Posts
