Sti Leaning Out during acceleration
Problem began again after we were cruising and under 4,000rpm low load no boost it jumped up to 18:1 stuttered for a second I left off then after that it would start to rise up acting like it wanted to lean out, it at times would rise up to 15:1 to 15.5:1
Parts are aem 340 pump Cobb 1050x injectors iag fuel rails and lines aeromotive fpr grimmspeed intake with box torque solutions turbo inlet
My fpr sits at 40-44 my intake temp was at 20-30, no signs of gas leaks anywhere, fuel pump duty was at 33% then 100% during wot before I started having this issue, I replaced front o2 sensor then the issue was fixed but came back, cleaned the maf, issue went away did a few pulls ran just fine didn’t lean out then it came back. Injector duty cycle was at 50% but I’m assuming it’s just because I’m on a stock turbo and stock tmic
What should I look for? Boost/Vacuum leak test, replace maf? Tune related?
