1 - 4 of 4 Posts
I had hit a curb going about 25 and i bent the lower control arm, tie rod, and the steering rack leaks about 4 drops a day. I replaced the lower control arm, inner tie rod, the ball joint, and the sway end link. The axel popped out from the rotor once but i then managed to pop her in again. All is well as far as looks so i put it on the road for a small test drive and i hear a very faint click noise when going straight and turning. Not in reverse though. Everything seems in place and the wheels dont make noise when moving them on jacks. Can someone please help me troubleshoot this?
Click sounds like a CV joint?
What about the steering rack and leak?
Taking a video will help alot with something like this. I would also recommending getting an alignment done to make sure anything else isnt bent and out of spec. The alignment will not fix your noise issue.
1 - 4 of 4 Posts
