1 - 20 of 38 Posts
2004 WRX Part Out 86k miles
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain
PE1820 Turbo - Upgraded VF30 $600
05 FXT 5 Speed Transmission 4.44 $750
05 FXT Rear Differential 4.44 $200
EJ20x Dual AVCS Heads (Bent Intake & Exhaust Valves) $400
EJ20x AVCS Intake Camshafts $150
EJ20x AVCS Exhaust Camshafts $150
STi AVCS Intake Camshafts $150
STi Non AVCS Exhaust Camshafts $150
AVCS Metal Cam Gears: IN RH #13320AA000, IN RH #13320AA001, IN LF #13322AA000, IN LF #13322AA001 and EX LF #13323AA001 $100
Plastic Cam Gears: EX LF #13054AA033 & EX RH #13049AA041 $50
AVCS Camshaft Actuator Covers #13191AA000 $10 set
Coolant Hard Lines $30
Coolant Crossover Pipe $40
Timing Covers $15 each (Have complete set except inner right)
JDM Engine Mounts $60
JDM Subaru Water Pump & Thermostat $50
OEM Harmonic Balancer / Crank Pulley $40
FXT Intake Manifold $100
Side Feed Fuel Rails $50
DW300 Fuel Pump $75
OEM Fuel Pump Hanger $75
Coilpacks #FK1086 $50 each
Axles $100 each
Engine Crossmember $150
Transmission Crossmember $100
Rear Differential "T" Crossmember $100
Rear Crossmember $150
Power Steering Lines $50
Power Steering Reservoir $25
Power Steering Pump Bracket $15
Steering Rack $125
AC Compressor $100
AC Compressor Bracket $15
AC Lines $25+
AC Tensioner $30
AC Condenser $50
Washer Fluid Tank $20
Radiator Fans $25 each
Clutch Master Cylinder $35
Clutch Slave Cylinder $30
Clutch Fork $20
Clutch Fork Rod $20
Clutch Line OEM $15
Pitch Stop $20
Wiper Motor $40
Wiper Linkage $30
Rear O2 Sensor #22690AA520 $35
Battery Power & Ground Cables $10
Horns $10 set
Fuse Box #82231FE010 SOLD
Alternator SOLD
Boost Controller SOLD
Uppipe SOLD
JDM EJ20X Longblock SOLD
MAF Sensor SOLD
Clutch & Brake Pedal Assembly SOLD
STi 555cc Yellow Side Feed Injectors SOLD
04 STi ECU SOLD
Battery Tie Down with Hardware SOLD
FXT Side Feed TGVs SOLD
04 STi Bulkhead Harness SOLD
04 STi Cluster Harness SOLD
04 STi DBW Gas Pedal SOLD
FXT DBW Throttle Body with MAP SOLD
TMIC Brackets SOLD
04 STi Engine Harness SOLD
Coolant Expansion Tank SOLD
Fuel Pump Controller SOLD
Rear Crossmember SOLD
Purge Valve SOLD
Purge Solenoid SOLD
Charcoal Canister SOLD
STi TMIC with Y Pipe SOLD
STI BPV with Hose SOLD
SPT Intake with Heatshield SOLD
GReddy Evo 2 Cat Back Exhaust SOLD
Perrin Inlet SOLD
Invidia Catless Downpipe SOLD
Grimmspeeed Hood Struts SOLD
Oil Catch Can with Lines SOLD
Front "U" Subframe SOLD
Exedy Clutch & Pressure Plate SOLD
Flywheel SOLD
Power Steering Pump SOLD
Exhaust Manifold SOLD
GMS Radiator SOLD
Driveshaft SOLD
Suspension, Wheels, Tires & Brakes
Rota Gforce 17x8 +48 Wheels with 225/45 General Altimax Artic Tires $800
Struts & Springs $300
Front Driver Knuckle $100
Sway bars $25 each
Rear Aftermarket Endlinks $25
Front Aftermarket Endlinks $25
Trailing Arms with Brackets $40
Front Calipers $75
Front Rotors $25
Rear Rotors $25
ABS Sensors $25
Brake Master Cylinder $25
Brake Booster $50
STi Aluminum Control Arms SOLD
Lateral Links SOLD
ABS Module SOLD
Stainless Steel Brake Lines SOLD
Proportioning Valve SOLD
Rear Calipers SOLD
Rear Knuckles SOLD
Front Passenger Knuckle SOLD
Exterior
Silver Kartboy Front License Plate Delete $20
Front Bumper Beam $100
Rear Bumper $200
Rear Bumper Beam $100
Trunk with Wing $200
Gas Lid $20
Wiper Arms $30
Trim & Weather Stripping $10+
Doors SOLD (have some other silver and grey GD rear doors)
Hood SOLD
Front Bumper SOLD
Side Skirts SOLD
Headlight Brackets SOLD
Taillights SOLD
Headlights HID Retrofit SOLD
Grille SOLD
STi Scoop SOLD
STi Intercooler Splitter SOLD
Mirrors SOLD
Fenders SOLD
Chassis SOLD
Interior
Dash $100
Cluster Surround $20
Door Handles $10
Passenger Airbag $50
E-Brake Handle $30
Map Light $25
Dome Light $20
Bugeye Door Cards $50 set
Visors SOLD
Delrin Black Teardrop Shift Knob SOLD
04 & 05 FXT Steering Wheels with Airbag and Cruise Switch SOLD
Clock Spring SOLD
2 Button Key Fob Remote SOLD
Fog Light Switch SOLD
Front Seats SOLD
Rear Seats SOLD
Door Cards SOLD
Carpet SOLD
6 3/4" Kenwood Speakers SOLD
HVAC Controls SOLD
Radio & HVAC Surround Trim SOLD
Auto Dimming Rear View Mirror SOLD
Subaru Tool Kit #97010FE040 SOLD
Center Console w/STi Shifter Surround SOLD
Gauge Cluster 86k Miles SOLD
Kenwood 4 Channel Amp #KAC-8402 SOLD
3rd Brake Light SOLD
Kartboy Shifter SOLD
Glovebox SOLD
Clock & Trim SOLD
2004 STi Gauge Cluster 98k Miles SOLD
Weathertech Floor Mats SOLD
Alpine Head Unit Bluetooth #CDE - HD149BT SOLD
Cup Holder SOLD
More Pictures:
1 - 20 of 38 Posts
