1 - 8 of 8 Posts
The block is a IAG trojan
Head is a w25 port and polished with a power decision 272 set of cams.lAG Fuel Rails
IAG Fuel Lines
ID 1300cc Injectors
Cobb Flex Fuel (Not Currently Tuned on e85)
Aeromotive Fuel Pressure Regulator
Cobb Fuel Pressure Sensor
Radium Drop in Fuel Basket
Walbro 450 Fuel Pump (Hardwired)
00000000000006
Radium Fuel Filter
Innovate Wideband AFR Gaug
Grimmspeed Uppipe w/ Tial 38mm EWG
6888888888888e
Invidia Catless Downpipe
Perrin Equal Length Headers
Perrin 3" Turbo Inlet
ETS 3" Intake
ETS 3.5" FMIC W/ ETS Front Chassis Bar
Tial Q Blow Off Valve
Visconti Speed Density Kit
IAG TGV Deletes
Air Pump Delete
IAG AOS
Cylinder 4 Cooling Mod
Grimmspeed Electronic Boost Controller
:.......00.....4
66884
Innovate Oil Pressure/Temp Gauge
Cobb Accessport
......0.0.0..
ETS Exhaust (Have both Extreme and Quiet)
ACT Heavy Duty Street Clutch
Fortune Auto 500 Series Coilovers (8k Springs)
......06.60...0.0.
Titan 7 TS-5 19x9.5" Wheels
Firehawk Indy 500 Tires (Tread @ 40% Life)
Hawk HPS Brake Pads
Stainless Steel Brake Lines
Slotted High Performance Rotors
ALL FLUIDS MOTUL:
Motul 5w-40 Engine Oil
Motul Transmission and Diff Oil
IAG Performance Stage 2 EJ25 11mm Oil Pump for
04-21 STI, 06-14 WRX, 05-09 LGT, 04-13 FXT
1 ea - SN(S): 01711;
FHI OIL COOLER COMPLETE W/ GASKET STI 08+
FHI E|25 Cam Sprocket LH Intake 06-07 WRX, 04-
07 STI, 08-14 WRX, 08+ STI, LGT, FXT
FHI E|25 Cam Sprocket RH Intake 06-07 WRX, 04-
FHI EJ25 Cam Sprocket RH Exhaust 08+ STI, 2010-
12 LGT
FHI E|25 Cam Sprocket LH Exhaust 08+ STI, 2010-
12 LGT
FHI EJ25 AVCS Oil Control Valve w/ Housing RH
Exhaust 08-19 STI
FHI EJ25 AVCS Oil Control Valve w/ Housing LH
Exhaust 08-19 STI
FHI EI25 AVCS Oil Control Valve Intake 10-19 STI,
10-14 WRX (10 Check VIN), 10-12 LGT, 10-13 FXT
IAG Timing Belt Kit with IAG Red Racing Belt, IAG
Billet Timing Guide, Idlers & Tensioner 04-21 STI,
06-14 WRX
IAG Performance El Street Series Oil Pan Kit w/
Pickup & Windage Tray Baffle for 02-14 WRX, 04-
20 STI, 05-09 LGT, 04-13 FXT (Silver)
IAG 0-100 PSI Fuel Pressure Gauge Kit
with 90 Deg. Fitting & Sealant
IAG Performance 0-100 PSI Liquid Filled
Fuel Pressure Gauge (Black Face)
Fitting Street Elbow 90 Deg, 1/8" NPTF
Male x 1/8" NPTF Female
Loctite 545 Pipe Thread Sealant, 0.02
OZ.
TURBO & ACC
BLOUCH TURBO DOMINATOR 4.0XT-R
IAG Turbo Heat Shield Blanket For
Subaru WRX / STI Stock Style Turbos
Hp guesses?
Tire Wheel Car Cloud Land vehicle
I’m gonna guess laggy? Lol.
nah I’m going to say low to mid 500s. With the limiting factor being the id 1300s. (Assuming e85). Wait time out. Read again, how are you being tuned with cobb flex fuel?
1 - 8 of 8 Posts
