Parts are from 1999 and 2000 RS coupes both 5 speeds.
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain Pics: EJ22 Phase I Long Block Fully Assembled $350
EJ22 Intake Manifold $80
EJ22 Throttle Body $40
EJ22 Engine Harness $50
RS 5 Speed Transmission $400
Lightweight Flywheel $60
6 Puck Clutch with Pressure Plate $50
Crankshaft Pulley $30
Plug Wires $30
Air Assist Injector $35
Timing Covers $10 each
Power Steering Pump with reservoir $75
Power Steering Pump Bracket $10
AC Compressor $100
AC Compressor Bracket $10
Rear subframe $40
Engine crossmember $60
Rear differential carrier 'T' subframe $40
Transmission subframe $25
Transmission mount $20
Gas cap $10
Fuel pump $20
Fuel pump assembly $20 (1 piece broken)
Fuel rails and lines $50
Fuel pressure regulator $25
Injectors $40 set
Clutch master $30
Slave cylinder $30
Steering rack $50
Throttle cable $10
Ignition coil $30
Plug wires $30 set
Throttle body $40
Oil fill neck and cap $15
Cam gears $10
Axle with one busted CV joint $25
Coolant overflow tank $10
Radiator fans $25 each
Air Box Intake Tube Resonator $25
Suspension, Wheels, Tires & Brakes Pics: Subaru Baja Wheels 16x6.5 +48 with 215/65 Winter Tires $300
Sway bars $30 each
Lateral links $20 each
Trailing arms $40 set
Endlinks $20 set
Control arms $25 each
Driver Front ABS sensor $20
Exterior Pics: Driver Taillight trim blue $20
Blue rear bumper $75
Blue trunk with small wing (has few dents) $50
Door windows $40 each
Hood release cable $10
Roof trim $40 each
Wiper cowl $25
Wiper motor & linkage $40
Sunroof frame $40
Hood prop $5
Interior Pics: Rear Seat $100
Steering Wheel $20
Driver airbag $40
Dash bar $50
Passenger Door Lock Actuator $20
Hood release handle $5
ECU metal cover $10
Wire covers for inside door kick panel $10 side
Fuel pump cover $5
Gas pedal $20
Blower motor $40
Rear view mirror $20
Map light $10
Steering column $50
Speaker brackets $10 set
Door Weather-stripping $5
Tweeter cover $10 each
Door panel bolt cover $5
Gauge cluster surround $10
Rear heat vents $20 set
Electronics Pics: Knock sensors $10 each
Door ajar sensor $10
Horn switch $20
Antenna with hardware $25
Airbag sensors $10 each
Airbag harness $25
Alternator to battery cable $10
Links to albums of individual pictures are located beside each group
Plug Wires $30
AC Compressor $100
Rear subframe $40
Gas cap $10
Fuel pump $20
Injectors $40 set
Clutch master $30
Slave cylinder $30
Steering rack $50
Throttle cable $10
Ignition coil $30
Plug wires $30 set
Throttle body $40
Cam gears $10
Sway bars $30 each
Endlinks $20 set
Roof trim $40 each
Wiper cowl $25
Sunroof frame $40
Hood prop $5
Steering Wheel $20
Driver airbag $40
Dash bar $50
ECU metal cover $10
Fuel pump cover $5
Gas pedal $20
Blower motor $40
Map light $10
Steering column $50
Horn switch $20
Airbag harness $25
