1 - 10 of 10 Posts
Car: 09 STI
Tuner: P&L Motorsport (Chicago, IL)
Dyno Info: Dynojet
Peak HP: 458.02WHP
Peak Torque: 466.23 ft/lbs
Fuel: E85
Date: Sep 26, 2014
Temp: +81F/+27C
Engine Managemen
COBB AP v2
OMNI-Power MAP 4 bar
GS EBCS
AEM AIT Sensor Kit (Relocated)
Motor
Rallispec RSB-SS25 Street Spec Short Block
Cosworth 4032 Pistons
ARP Custom Age 625+ (260-4704)
Supertech Stainless Valves
TGV Delete & Air Pump Delete
Turbos
Blouch DOM 2.5 XTR 10sm 2.4'' IWG
Cooling
Mishimoto X-Line Performance Aluminum Radiator
Evans NPG+C coolant
Fuel Systems
ID 1000cc
AP Fuel Rails for '07
Aeromotive FPR (set to 64 psi)
Aeromotive 340lph
NGK2309
Air Induction
CNT FMIC
Perrin Turbo Inlet 2.4"
P&L HighFLO Intake 75mm
TurboXS H34 BPV
Exhausts
CNT DP 3'' (catted)
Maddad Whisper CBE
Tomei ELH (wrapped)
Oil Systems
Moroso AOS (MOR 85510)
Redline 5w30 Oil+Tokyo Roki Oil Filters
Drivetrain and Transmission
Perrin LW Pulley
ACT HD+4-Puck Clutch
Wheels
SSR Type-F 17.9lbs
245/40R-18 Bridgestone RE-11
Discussion Starter #4
Yeah. this setup on its max. I may squeeze another 15-20whp (catless+bigger filter for intake) on it but not more. Time to go rotated I guess.
Discussion Starter #9
have ~50K miles on that block. Last time I checked it had 3 cylinders at 140psi and 1 (4th) at 130psi. Had HG replaced within 1st month I did 390whp->460whp transition. Standard ARP head bolts happened to be just too weak for torque/pressure created by E85 - don't know why rallispec insisted on using those. I wanted to put CA 625 right away. Anyway. Switched to ARP Custom Age 625+. Put 10K miles since. have no issues.
rallispec ... if you ask them to assemble long block, dbl chk their work at the end. The did a great job but forgot to torque/seal service plugs and those started to leak oil right after I put engine back in the car. Had to redo process again.
1 - 10 of 10 Posts
