1 - 4 of 4 Posts
Hey guys. when my car has been sitting overnight, it sometimes says my coolant temp is maxed and then kills the motor and fans are running as fast as they can. I’ve had it happen a few times before and thought it was just getting false readings from humidity in morning because I’d get home from work and it’d turn on no problem. Put it in the garage and didn’t have any problems for a couple months. The past few days, it hasn’t turned on at all. Getting a code (P0117 - Engine coolant temp sensor circuit low input), just curious if anyone’s had this issue before and if so, how’d they resolve it? Thanks in advance, Justin
Discussion Starter #2
The car is completely modified by the way. Basically nothing stock in engine bay at this point
1 - 4 of 4 Posts
