1 - 20 of 1172 Posts
Journal First Post wiped out/updated:
New build starting NOW: 9/19/2012 .... Read below.... you won't want to miss this. Mod list updated.
MOD LIST BREAKDOWN:
(Rally Blue = Installed/Purchased Mods, Red = Coming Soon, Black = Potential Upgrades)
  • Engine/Exhaust:
    • Garrett GTX3071R .63 Tial V-band Exhaust Housing
    • Fully Forged Short Block w/ Darton Sleeves, Stock Nitride Crank, CP Pistons, various other bits, will update later
    • BC S2 Cams, Springs, Retainers and mild PnP job by myself
    • Cometic Head Gasket
    • Gates Racing Timing Belt Kit
    • Tomei Timing Belt Guide
    • AVCS Delete, WRX Cam Gears
    • Supertech Inconel Exhaust Valves, SS Intake, Std Size
    • Area 1320 Custom Rotated Downpipe w/ electronic exhaust cutout (316L medical grade)
    • Area 1320 Custom Up-pipe / Dump Tube w/ Tial 38mm EWG (316L medical grade)
    • Area 1320 Custom Intake
    • Area 1320 Custom V-Mount Intercooler
    • Mishimoto MR2 Radiator -- modified for v-mount application
    • Greddy Ti-C converted to v-band
    • Greddy Mid-pipe has flex connector installed + electric cut-out + turn down
    • Tomei EL Headers
    • P&L Air Pump Delete
    • Hallman Pro RX Boost Controller
    • Turbosmart RacePort BOV
    • ATI Super Damper
  • Electronics:
    • Carberry Engine Management + Omni 4 Bar MAP speed density
    • AEM Digital Gauges: Oil Temp, Oil Pressure, Boost, Wideband
    • Odyssey PC680 Battery relocated to the boot
    • Racepak IQ3 w/ Data Logging
  • Fueling:
    • Aeromotive 340 In-Tank Pump
    • Deatschwerks 1000cc Injectors (flow tested/cleaned 1050cc+)
    • Agency Power Fuel Rails
    • Aermotoive Fuel Pressure Regulator
    • Integrated Engineering Surge Tank / Bosch 044 submerged (-6AN)
    • Fuel Lab 40 micron Stainless In-Line Fuel Filter w/ check valve
    • Aeroquip -6AN Stainless Lines throughout w/ Aeroquip fittings
  • Oiling:
    • Killer B Motorsports Oil Pan, Pickup
    • Canton Racing Accusump (2QT, -10AN)
    • Canton Racing Electronic Valve Controller
    • Aeromotive Billet Check Valve
    • Mocal 235matrix 25 row Oil Cooler (-10AN)
    • 190F Mocal Thermostat Sandwich Adapter
    • Aeroquip -10AN stainless lines throughout oiling system
    • Canton Racing 6" CM in-line oil filter
    • Peterson Fluid Systems Breather Can
  • Track Prep / Cooling / Braking
    • WRC V-Mount Intercooler Vent
    • RunCool Hood Louvers 11"x17"
    • CF style Aerocatch latches
    • RaceTech RT4009WHR Seat
    • Planted Technology Seat Bracket
    • Planted Technology Seat Base
    • P&L SS Clutch Line
    • P&L SS Brake Lines
    • Hawk HPS Pads
    • Spare and other misc parts removed
  • Drive Train:
    • Competition Clutch + Flywheel
    • Kartboy Rear Shifter Bushing
    • Perrin Front Shifter Bushings
    • Torque Solutions Engine, Tranny, Pitch Stop, Short Shifter
    • Cusco Rear Diff Inserts
    • WL Rear Subframe Inserts
    • TiC Tranny Crossmember Bushings
    • TiC Holy Shift Set
    • Kartboy Rear Subframe Bushings
  • Wheels / Tires:
    • 335/30/18 Toyo R888
    • 18x12 +12 Forgeline GA3R
    • 2.5" Bolt on Flares
  • Suspension Upgrades:
    • Fortune Auto 510 V4 Coilovers 8kF/9kR Swift Springs + Roller Bearing Upgrade
    • Cusco Rear Adjustable Lower Control Arm
    • Cusco Front Lower Arm Bar Type II
    • Cusco Front/Rear Strut Bars
    • Kartboy Front/Rear Endlinks
    • Whiteline 22mm Front Sway Bar,Whiteline 20mm Rear Sway Bar
    • Whiteline Rear Sway Bar Mount Reinforcements
    • Whiteline Steering Rack Bushings
    • Whiteline Front Control Arm Bushings
    • Whiteline Roll Center Kit
    • Whiteline Rear Toe Arms
  • Exterior/Misc:
    • 2011 STi Bumper w/o fogs
    • Perrin Shorty Antenna
    • 25% Tint
  • Fluids:
    • Amsoil 5W40 Signature Synthetic Engine
    • Amsoil 75W90 Synthetic Transmission / Diff
    • Amsoil 600 DOT 4 Brake Fluid
    • Amsoil Power Steering Fluid
    • Amsoil Dominator Coolant Boost
Re: sysfailur -> AW 08 STi - Update: HKS Exhaust arrived!
Tips look great, but the can looks kinda cheap. All in all a great looking setup though. Any plans for a DP?
Updated main post w/ future mod wish-list of sorts. It's in my plans for the future but as of right now, nope.
TBH a new headunit is what I'm wanting more and more right now. NEEDS THE MEWSICS!
Also, the can really is sturdy. Everything seems top notch to me. Even has like a "JASMA" plate bolted onto the can and the centerpipe instead of a sticker which I thought was pretty cool.
Discussion Starter #6 (Edited)
Exhaust installed, sounds great! I will post pics/vids tomorrow most likely.
Some notes also: Install was really easy, fitment was great, and the sound is deep and smooth.
Nice work, looks good :tup:
Discussion Starter #10
Thx guys, I just got home but tomorrow I'm gonna do a buncha HD filming of this. Some drivebys, maybe a little tunnel action! There's only one tunnel near me, and I gotta pay like $1.50 to go on that stretch of turnpike but, I think imma do it cus it does sound friggin awesome.
Discussion Starter #14
Re: sysfailur -> AW 08 STi - Update: HKS legamax installed pics/vids
Here's the vids in HD, sized down a bit. They're in .wmv and should open in VLC or WMP.
1) 71mb - Start up car, first takeoff + driveby.
2) 40mb - 2nd driveby at around 40-45mph or so.
3) 38mb - Blowby in 3rd @ near 6k rpm w/ backoff of throttle.
4) 68mb - Probably my fav. Come to a stop, turn around, near WOT drive-off.
5) 34mb - Shutting off car.
6) 47mb - A little in-car action, windows up, it was hard to position so I didn't record a lot--got up to around 80mph, I think I got up to 4th, 5th gear maybe?
7) 76mb - @ Car wash, a little rev action
8) 31mb - @ Car wash, a close up shot of exhaust + idle sound.
Needless to say, I love how this sounds! Turn up your volume, your bass, and let it rip!
Sounds sweeeeet man. I didnt think i liked the HKS exhaust, i thought it sounded too tame or maybe "ricey" from other clips i heard but in your clips it is definately badass. :tup: :tup: :tup: Are you running an AP for stage 1? And did you notice and increase in throttle response, torque, hp?
hks in my opinion made the best looking exhaust for the 08s, but don't mind me, i'm based. :lol:
Discussion Starter #18
I am not running an AP, no downpipe, no CAI. It's on my list but don't have the cash atm. And tbh it's hard to tell a difference. I would say yes, I can tell a difference but I'm sure it's just butt-dyno at this point until I get tuned.
All in good time.
Is there anything wrong with the files? My comp has been acting up since I downloaded the files.
Discussion Starter #20
By your name, I would guess you're using a Mac? If so, I would think maybe you're just missing the proper codec--but they all work for me. They're just your standard .mpg file.
