21 - 29 of 29 Posts
Discussion Starter #22
Hi. Make some offers. No reasonable offer refused.
Aftermarket parts are gone but I have a ton of oem stuff left
Discussion Starter #24
parts left:
Secondary Air pump with bracket - $180
Exterior window B Pillars Mounting bracket - $80
New Camber Bolts for rear wheels - $15
Brake Master Cylinder - $60
Turn signal switch - $25
Headlight switch - $25
Trunk Weather Strip - $30
Driver Headlight (cracked but projector and and ballast are good) - $50
Radiator/ Coolant Cap(s) (new and used) - $15 for oem $20 for Mishimoto Radiator Cap
OEM dash board (Black) - $150 [local pickup preferred]
Glove box - $40
Passenger airbag (Black) - $200
Red Intake Manifold w throttle body - $250
OEM center console w ebrake boot and center console- $85
OEM dash cluster surround bezel - $25
Radio surround dash trim w bracket- $50
Fuel Tank [local pickup preferred] - $80
OEM Starter - $80
OEM Alternator - $100
AC Compressor - $100
Air Conditioner Lines - $100
OEM Brake Master Cylinder - 1
$100
Subaru OEM Coolant (Concetrate) - $15
OEM Intercooler Water Reservoir with cap, motor and lines attached - $130
Air Intake Heat Shield (missing 1 small screw hole)- $30
Torsion Bar for Trunk Wing so that it doesn't slam down - $50
All window switches - $100
Gas Cap and Door (OBP color) - $50
Trunk & Gas Cap Openers with cables - $60
5x114.3 Spare Tire with offset for big brake kits / calipers, never used - $100
Wiper Motor - $80
Wiper Cowl - $80
Heater Core - $100
AC Blower - $100
Kicker Interior Speakers and brand new 4ch amp - $200
Kicker Solo Baric L7 12" in enclosed box- $200
Set of door locks, trunk lock OEM security keys, Ignition and immobilizer plus ECU - $700
Steering Column - $60
Exhaust Hangers - $20
Also available: All bolts, under car Heatshields, brackets and entire wiring for entire car -
make an offer for what you want.
I have other misc parts, trims, bolts, brackets.... so just ask
21 - 29 of 29 Posts
