1 - 20 of 29 Posts
Here's what I have left from my 07 STi Subaru Impreza Partout
Text me: 973.277.9301
Email: [email protected]
Secondary Air pump with bracket - $100
Exterior window B Pillars Mounting bracket - $50
New Camber Bolts for rear wheels - $15
Brake Master Cylinder - $40
Turn signal switch - $20
Headlight switch - $20
Trunk Weather Strip - $20
Driver Headlight (cracked but projector and and ballast are good) - $40
Radiator/ Coolant Cap(s) (new and used) - $10 for oem $15 for Mishimoto Radiator Cap
OEM dash board with airbag (Black) - $250
Glove box - $30
Red Intake Manifold w throttle body - $200
OEM center console w ebrake boot and center console- $65
OEM dash cluster surround bezel - $15
Radio surround dash trim w bracket- $30
OEM Starter - $60
OEM Alternator - $80
AC Compressor - $80
Air Conditioner Lines - $80
Subaru OEM Coolant (Concetrate) - $10
Torsion Bar for Trunk Wing so that it doesn't slam down - $40
All window switches - $80
Gas Cap and Door (OBP color) - $40
Trunk & Gas Cap Openers with cables - $40
5x114.3 Spare Tire with offset for big brake kits / calipers, never used - $60
Wiper Motor - $60
Wiper Cowl - $60
Heater Core - $80
AC Blower - $80
Set of door locks, trunk lock OEM security keys, Ignition and immobilizer plus ECU - $600
Steering Column - $40
Exhaust Hangers - $10
Also available: All bolts, under car Heatshields, brackets and entire wiring for entire car - trims, bolts, brackets.... so just ask
How does the front subframe look? I'm looking for one that's not destroyed by rust.
Hi, when I installed the front strut bar years ago, I dropped it and painted it with rustoleum, to prevent rust or issues. I did the same with all major metal components under car (diff mount, subframe, etc.).
New Camber Bolts - $15, do these allow more camber than stock? Front or rear? Torsion Bar for Trunk Wing- $50 I find the bar on my 2006 STI is weak, is this stronger than stock? Kicker Interior Speakers and brand new 4ch amp - $200 Please detail all speakers included and make & model of amp.
Discussion Starter #6
Camber bolts are for rear. More camber than stock
I don't know if there is a reason why your 06 torsion bar is weak. Mine held my winged trunk very well. Maybe yours is bent or broken
I can send you pics of all speakers and amp... I also have a capacitor for the system. Text me
Discussion Starter #7
Weekly bump... I wish half these things were available when I was doing a build a few years back!!!
Discussion Starter #11
Yes, text or email me
Just a shot in the dark, but have you sold the hood/hood scoop already?
Sent from my iPhone using Tapatalk Pro
Yes, sorry. I have the following parts left:
wiring harness, fuel tank, dash, control arms, all window switches, many interior plastic trims, window pillars, some metal subframe pieces, center console, heater core, ac blower,* left and right skid plates, some motor accessories* (ps pump,* starter, alternator), steering column, ecu, key set w locks and some other stuff.
1 - 20 of 29 Posts
