I have a Spec C trunk with holes for a WRX spoiler. I have decided to go wingless until I can decide on a spoiler. At first, I was going to go with the S202 replica, but it is very very heavy... 3.8 lbs for the wing and 8 lbs for the STEEL brackets. There is an S203 replica that weighs about 1 lb for the wing and 6 lbs for the steel brackets, but it does not fit the WRX pattern. There are other wings out there with aluminum brackets but are almost $1500!!! For that, I might as well get the genuine S203 or S204 wing for $1000... or just get the replica for $500.
The body shop I'm dealing with says tig welding the aluminum requires too much heat and because the metal is so light and thin, it will distort it and mess it up... so I've decided on rubber, plastic, or vinyl plugs for now. What do you guys suggest and where do I get them?
