Ok, so here is whats up. I spun a rod bearing, number 1 (which seems odd from all of the research ive done). Well damage to the crank wasnt too bad, its at a machine shop right now, they are grinding it .010 under on all rod journals, and ill be running appropriately sized bearings for the machine work. So obviously ill be getting new pistons, and while im at it, im going to get some new rods (might as well, one is damaged and why not have some security with my rebuild). I am leaning towards manley turbo tuff rods, and maybe the turbo tuff pistons or a set of mahle pistons. I will probably get a slight over bore (.25-.5 mm, so 99.75-100 mm) to get some fine scratches out and to make sure the bore is round. (64xxx on stock block, bought it used with 63xxx). With my build i am looking to make 400 awhp on 91 (Flame on!). I dont have access to 93 or E85, so ill be looking into water/meth manly for det reasons. So, lets hear your thoughts on my rod/piston combo, also if you have different suggestions, lets hear them and the reasons why. I searched and found a few threads, but they either got hijacked or there was no real reason why someone chose what they did, other than so-and-so has had good luck with it.
Also, my turbo is pretty well toast, so lets here some suggestions on those, i would like to go rotated but i also know there are some good stock location turbo options.
There is currently a turboxs fmic, catless up pipe, hks hi-power tbe, cobb sf intake and cobb ap.
So lets here it people. Thanks.
Also, admins, i think this is in the right area, if not, sorry, move as needed.
