Not sure if this is the right section, but since it's in the engine bay, I figure close enough
From what I've observed, these fans are pretty much identical except the radiator fan (driver side) has a bigger motor and is 1 lb heavier.
Also based on my observations, the fans always come on and off together... when you turn on the AC, both fans come on regardless of temperature of the coolant or engine bay. When the car starts to get hot, both come on at the same time.
I've removed my AC system and do not plan to put it back.
I plan on selling my driver side fan which is the main rad fan... I plan to keep the passenger side fan for backup... if I ever run a fan, I would only run 1 fan... and since that is the lighter one and located on the passenger side for better weight distribution, I will keep that one.
However, if I'm wrong about my observations, then I should keep the driver side fan (rad fan) and sell the condenser fan (pass side).
Can somebody confirm? Thanks.
