T-Gs Air to Water IC Build - Page 41 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > T-Gs Air to Water IC Build
Old 06-23-15, 04:28 PM   #401
1breel
Contributor
Car: 02 GGSTi
Fav Mod: haven't bought it yet
1breel is an unknown quantity at this point
Default Re: T-Gs Air to Water IC Build
Originally Posted by StiLimited View Post
Water is 8.4#/gal so that's easy to figure, but how much does the AWIC, pump, tank and plumbing weigh?
Good question but not easy to answer for the simple reason that any two are not the same for the most part. Too many variables with IC core size, radiator choice and material used for plumbing. I'd venture to say that the total weight minus water would be close to the same as an AWIC setup. I like the ease of plumbing a couple of AN-12 lines instead of fighting with 10 foot of 3" tubing.
1breel is offline
Old 08-11-15, 07:42 AM   #402
1breel
Contributor
Car: 02 GGSTi
Just in case anybody still wants to use this setup, the AC drier clamp from a 93-99 Impreza or Legacy is the same diameter as the Bosch water pump. This way you can have a factory clamp to hold the pump, plenty in the junkyard, and far cheaper/better than anything offered besides some custom overpriced billet part.
1breel is offline
Old 08-12-15, 01:20 AM   #403
Shadow27
Joined the Conversation
Car: Silver 03 WRX STi
Shadow27 is an unknown quantity at this point
Thank you so much for the original build post T-G.
Here is my attempted:
Frozen boost core and radiator, Davies Craig 115L/h water pump, washer bottle used as reserve, pre and post cooler temp probes.
Engine setup:
- EJ207 AUS V7 forged bottom end
- JDM Spec C V9 big port heads
- ARP 625 studs
- GTPumps GTPS02 TD05 20G 7cm @ 25 psi
- Walbro 460 fuel pump
- ID1000 injectors
- Process West 72mm intake
- AVO silicone inlet
- PSR equal length headers
- Hyperflow catless dump to 100 cel race cat to Invidia Q300 catback
Dropped 400-500 rpm off spool time over Process West FMIC setup I had before. Here is a video to show response from a roll out to 8000rpm each gear:
https://www.youtube.com/watch?v=vKcd...0&spfreload=10
Cheers!
Shadow27 is offline
Likes 3 Dislikes 0
Old 08-31-15, 10:40 AM   #404
maxouni
maxouni is an unknown quantity at this point
Very informative thread.
What about use AC radiator with modified fittings as heat exchanger?
maxouni is offline
Old 08-31-15, 10:42 AM   #405
maxouni
Double post.
maxouni is offline
Old 06-20-16, 10:35 PM   #406
Afrikantk
Advanced Contributor Level 2
Car: 2011 Scoob
Fav Mod: V1/ Advans
Afrikantk is on a distinguished road
Interesting read.
Afrikantk is offline
Old 06-23-16, 09:16 AM   #407
Voodoo Rufus
Fav Mod: Driver Mod
Voodoo Rufus will become famous soon enough
Engine setup:
- ARP 625 studs
- ID1000 injectors
Cheers!
Super clean! I'd like to know what exact heat exchanger part numbers you use, and how you connected the turbo to the intercooler.
Voodoo Rufus is offline
Old 10-20-16, 02:13 AM   #408
2bfi
Advanced Contributor Level 3
Feedback Score: 2 reviews
Car: 2011 WRX STI
Fav Mod: Lightweight flywheel
2bfi is on a distinguished road
Here is how I did mine.
The inlet and outlets ports are not the highest point of the heat exchanger. So, I installed it with the drain valve on top and use it to bleed out trapped air.
If you use the frozenboost.com heat exchanger, pay attention to the 1/8" NPT plug right below the drain valve. Mine was leaking and tightening did not help. It came with a gasket that was a rubber coated washer or something like that. I replaced it with a 1/8" NPT plug and some teflon tape.
I'm still in the cautious testing stage. Most of the driving is in heavy traffic. I haven't had the chance to do some good pulls. Even in heavy traffic, the AWIC unit just gets warm.
May 17, 2017
Just a little update. I've installed an GM IAT sensor on the AWIC's outlet side end tank. (pretty much ready for SD tuning) IATs are about 12-15 deg. C. above ambient. Heat soak is a thing of the past and car feels peppier even after sitting in traffic.
With OEM TMIC, I'd see very occasional knocks in the 1.0-1.3 g/s column. With the AWIC, it has dropped to almost none. I've seen only 2 knocks in 5 months of driving.
I'm very happy with the results. BTW, I'm running an ATP GT3071R at 20 psi.
2bfi is offline
Likes 2 Dislikes 0
Old 11-09-17, 01:54 PM   #409
Turbineguy
Feedback Score: 10 reviews
Car: '06 WRB
Fav Mod: Liquid Thermal Management
Turbineguy is on a distinguished road
I have risen from the dead. Been outta the loop for far longer than I care to remember but as an update to this whole nut roll the AWIC is still fully functional and have had no issues with it save for the bearings in the pump motor getting worn and noisy. Hasn't leaked a drop, temps stay solid with very little fluctuation and makes tuning much easier as a result.
"Straight roads are for fast cars, turns are for fast drivers." -Colin McRae
"It's not a throttle-it's a detonator." -Jeremy Clarkson
"Aerodynamics are for people who can't build engines." -Enzo Ferrari
"Give a man fire and he is warm for a day, set him on fire and he is warm his whole life."-Terry Pratchett
T-Gs AIR TO WATER INTERCOOLER BUILD THREAD:
https://www.iwsti.com/forums/water-me...tercooler.html
Turbineguy is offline
Likes 2 Dislikes 0
Old 11-16-17, 11:04 AM   #410
Voodoo Rufus
Fav Mod: Driver Mod
How are these setups holding up under track day sessions?
Similar Threads
Over the seas 06 STI !The big build begin + random pic's of cars in Jordan post #116 z38er GD-Members' Journals 167 03-21-15 08:07 AM
FS (MN) Intercooler water spray kit STIhellride2005 Engine/Drivetrain/Performance Parts For Sale 1 04-22-10 10:33 PM
APS Intakes, BOV's, Interoolers, Turbos, and all other APS items back in stock! RallySportDirect GR-Engine, ECU, Power, Drivetrain 2 08-04-09 01:14 PM
AMS Top Shop Engine build..the quest for 1000hp on 100octane! AMS Vendor Announcements & Project Buildups 8 11-05-08 04:58 PM
Intercooler water tank Shicane 2.5 Liter/Litre Factory Motor 5 07-29-05 08:42 AM
