T-Gs Air to Water IC Build - Page 30 - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > T-Gs Air to Water IC Build
Old 12-01-11, 02:49 AM   #291
crashtke
Advanced Contributor Level 3
Car: 03 WRX, 05 LGT
crashtke is on a distinguished road
Default Re: T-Gs Air to Water IC Build
Just a thought, but has anyone considered the dual small heat exchangers with fans in each fog light area like the Porsche turbo cars use? They use twin exchangers (and you can upgrade to a third small one in the middle) linked together and placed in each front corner. Just something my friend and I have looked at.
--Sargent
My Borg Warner Bugeye
crashtke is offline
Old 12-01-11, 04:38 AM   #292
Fujiwara
Advanced Mastery Level II
Feedback Score: 5 reviews
Fav Mod: Experience
Fujiwara is an unknown quantity at this point
I've been thinking of an alternate exchanger. Goals: sleeper and massive surface area. Think I have the perfect spot
Fujiwara is offline
Old 12-01-11, 06:42 AM   #293
Fujiwara
Fav Mod: Experience
Originally Posted by thundercamel View Post
I agree. Anything that can make sub-ambient intake temps endlessly (not meth) only makes sense if you're chilling your reservoir for a short burst of power. I care mostly about road courses. If you have a device that can keep your intake temps sub-ambient while on a road course, than you're loosing more horsepower either through the alternator or AC compressor to chill the air, than you're gaining from the cool air.
Kinda like every step of the machine has inefficiencies that makes perpetual motion impossible. If your car is a closed system, I don't think you could ever gain power by using power to chill intake air.
Also also, I'll admit, the fuel must be considered outside of the engine's "closed system," and cooler air should let you use that fuel more rapidly for more power, but good luck with inefficiencies trying to cool that air. I feel like I'm babbling now, and must stop.
After careful thinking, I came up with a simple metaphor that should be able to tactfully explain why I think differently. A turbocharger scavenges energy from flowing exhaust gasses to make more power. We see very large gains in power per liter of displacement in engines by putting a device on it that forces more air into the cylinder. More air = more power. The idea behind lower temperatures is denser air. Using your closed system logic, then a turbocharger should not cause an engine to make more power. Ergo, using the energy of the system to force a larger amount of air into the cyliners can and will produce more power than is used to drive the device if it is engineered properly.
Fujiwara is offline
Old 12-01-11, 06:54 AM   #294
T3h_Clap
I Solve Problems
Feedback Score: 14 reviews
Fav Mod: TiC SST's and Vorshlag Plates
T3h_Clap will become famous soon enoughT3h_Clap will become famous soon enough
I've thought about this as well, either up front or have one exchanger at the rear of the car as well to make it look like a rear diff cooler.
Where you thinking? Spill the beans!!
T3h_Clap is offline
Old 12-01-11, 07:10 AM   #295
Fujiwara
Fav Mod: Experience
Type 100 sized exchanger in the frame. It would still sit infront of the radiator and such, but from the outside perspective people would think upgraded radiator. The massive surface area of the type 100 is enough for 600-1200 HP according to frozenboost... it's just a matter of fitment at this point.
Fujiwara is offline
Old 12-01-11, 07:30 AM   #296
T3h_Clap
I Solve Problems
Would there be any issue fully blocking the radiator?
HE, AC Con, Radiator?
T3h_Clap is offline
Old 12-01-11, 07:54 AM   #297
Fujiwara
Fav Mod: Experience
I'd say not a huge issue. Air will still pass through, granted have not seen people try it yet. If I do go that route, I'll be upgrading my radiator and fans along with shrouding the area properly to increase air flow over the system.
Fujiwara is offline
Old 12-01-11, 08:05 AM   #298
Fujiwara
Fav Mod: Experience
And as I drove to lunch I thought about your question. S2Ks usually use an air to air intercooler that completely blocks the radiator. Some kits like the greddy upgrade the radiator and the shroud to combat the decreased air flow and higher temperature of the air.
Fujiwara is offline
Old 12-02-11, 02:36 PM   #299
iampnp
Feedback Score: 1 reviews
Car: WRB 07 STi
Fav Mod: Moar Powaa?
iampnp has a little shameless behaviour in the past
Would a V-mount setup alleviate the cooling issues?
iampnp is offline
Old 12-02-11, 02:47 PM   #300
Fujiwara
Fav Mod: Experience
Id hesitate to go that route. Stacking should be fine as long as the radiator still gets enough air flow.
Fujiwara is offline
Similar Threads
Over the seas 06 STI !The big build begin + random pic's of cars in Jordan post #116 z38er GD-Members' Journals 167 03-21-15 08:07 AM
FS (MN) Intercooler water spray kit STIhellride2005 Engine/Drivetrain/Performance Parts For Sale 1 04-22-10 10:33 PM
APS Intakes, BOV's, Interoolers, Turbos, and all other APS items back in stock! RallySportDirect GR-Engine, ECU, Power, Drivetrain 2 08-04-09 01:14 PM
AMS Top Shop Engine build..the quest for 1000hp on 100octane! AMS Vendor Announcements & Project Buildups 8 11-05-08 04:58 PM
Intercooler water tank Shicane 2.5 Liter/Litre Factory Motor 5 07-29-05 08:42 AM
