Ok guys im going to do this. The season might be over soon but the war isnt. I think im the best person to this because im bias to the whole thing anyway. As most of you know i drive a forester xt. This is going to be whole new thread that will be updated EVERY DAY. If there is nothing for the day I will still be watching it. I will be only posting times that have an actual TIME SLIP.
There will alsoo be a list of modifications with symbols. The mod will have a corresponding symbol. For example: A=air intake.
Not only that.. I will be posting up fastest "stock turbo" STi according to year, octane level usued, injection and so forth...
A TIME SLIP MUST BE SHOWN
If you are NOT stock turbo.
Please Please tell me the type of turbo. After that you can use the symbols after that. These cars will be listed separately according to brand of turbo. There will also be an general fastest STi part of this thread.
If you do not see your turbo listed, please specify.
At first you will not see any turbos listed. When more people post and list there mods, the thread will be edited....
Please Specify if you are stock or aftermarket turbo....
A=Air intake (CAI, WAI, Green, K&N, etc)
B=Upgraded Blow-off Valve/Recirc Valve
C=Clutch
D=Downpipe
E=Exhaust
F=Flywheel
G=Head work (porting, etc)
H=Upgraded Header or ported
I=Upgraded Intercooler
K=Upgraded Scoop/Splitter
L=Lower end work (pistons, etc)
M=Manual Tranny gearset/Swap (PPG, Kaaz, 6MT)
N=Nawwwwsssss
O=Short shifter
P=Underdrive pullies
Q=aftermarket differential
R=Race fuel
S=Suspension
T=ECUTek, AP, UTEC, etc...
U=Uppipe
V=Upgraded turbo
W=Weight reduction (other than just spare, jack, babyseats and floormats)
X=Cams
Y=Ported TB
Z=Stand alone fuel management
&=Aftermarket Boost Control Solenoid (Perrin, GM, etc...)
%=Shifter Bushings
*=Tranny Mount
^=Motor mounts
}=Slicks/Drag Radials (not that anyone needs them...yet)
{=H2O and/or Alky injection
+=TGV Delete
Wanna get on the list? Here's all you have to do:
Submit your info in the following format:
Screen Name - X.XXX 60', xx.xxx @ xxx.xxmph (2 digit Year and Model, Transmission Type, Color) Mods (see legend) (outside temp, pressure would be helpful) (state and track)
Only post your 1/4 times. Please try not go way OFFTOPIC!! We already know it takes more skill to turn. :wink:
C=Clutch
D=Downpipe
E=Exhaust
F=Flywheel
N=Nawwwwsssss
O=Short shifter
R=Race fuel
S=Suspension
U=Uppipe
V=Upgraded turbo
X=Cams
Y=Ported TB
%=Shifter Bushings
*=Tranny Mount
^=Motor mounts
+=TGV Delete
