Dampa's CBS '15 STI **Closed deck/PTE6466** - Subaru Impreza WRX STI Forums: IWSTI.com
STI Forum
Join
Go Back   STI Forums > > > Dampa's CBS '15 STI **Closed deck/PTE6466**
Old 02-22-15, 10:47 AM   #1
Dampa
Advanced Contributor Level 4
Feedback Score: 0 reviews
Fav Mod: E85
My Threads
My Subaru Parts for sale
Dampa is a jewel in the roughDampa is a jewel in the roughDampa is a jewel in the rough
Default Dampa's CBS '15 STI **Closed deck/PTE6466**
-------------------------Contents-------------------------
2015
02/11/15 - STI arrived at Heuberger
02/16/15 - Picked up my STI
02/17/15 - RCE Yellows / Perrin 20 mm spacers installed
03/21/15 - Lamin-x fog overlays, NAV screen mod & debadge
03/22/15 - Kartboy Short Throw Shifter
04/18/15 - Prosport Gauges & Diode Dynamics Tail as Turn
04/25/15 - IAG Performance Competition AOS
05/09/15 - Bayson-R Front Lip
05/30/15 - GrimmSpeed DP, Tomei Ti and AEM CAI
06/13/15 - CamTuning Pro Tune
08/28/15 - Exhaust swap: Invidia Q300
09/12/15 - Torklift Eco Hitch
11/08/15 - ID1000's, IAG Fuel Rails, DW65c, Zeitronix Ethanol Analyzer
11/10/15 - Dyno Tune for E85 by CamTuning
2016
02/01/16 - Wingless Trunk Swap
02/12/16 - Extended Gas Pedal, SMY Interior Deco, Perrin Pitch Stop install
02/13/16 - AEM Wideband, HT Autos Rear Spats
03/08/16 - Torque Solution Transmission Mount
03/08/16 - Off-The-Line Performance Closed Deck Block
04/26/16 - Mach V Awesome Wheels and Nitto nt555r's
05/20/16 - Test n Tune at Pacific Raceways 12.5 @106mph
05/29/16 - The rebuild begins!
06/26/16 - ETS rotated kit and PTE 6466 arrive!
07/07/16 - Motor goes back in, ETS rotated kit installed
07/24/16 - Re-install complete, ready for engine break in
09/04/16 - Radium Dual Hanger Install
09/11/16 - 92 Street Tune, BC280 Cam Failure
09/25/16 - Head & cam damage
10/01/16 - BC sends complimentary replacement cams
12/06/16 - HIC Roof Visor
2017
01/09/17 - Repaired heads picked up from machine shop
01/18/17 - The Re-Rebuild is finally complete!
01/24/17 - 92 and e85 tune from CamTuning, 750hp/640tq at 38psi
04/11/17 - Pacific Raceways WA Test & Tune 11.1 @ 127
07/21/17 - Heartland Park KS Test & Tune 10.7 @ 135
-----------------------Current Mods-----------------------
Follow me on Instagram @sinister_sti
12.5 @ 106 mph on E85, 24 psi (stock turbo, stock motor)
345 hp & 438 lb-ft on E85 (stock turbo, stock motor)
309 hp & 363 lb-ft on NM 91 (stock turbo, stock motor)
10.7 @ 135 mph
751 hp & 643 lb-ft* on E85 (6466, closed deck, 38psi)
508 hp & 433 lb-ft* on 92 (6466, closed deck, 25psi)
* Virtual Dyno numbers, havent had the chance to throw the car on a dyno yet.
Motor:
  • COBB Accessport V3 (Protune by CamTuning)
  • IAG S3 Closed Deck from Off The Line Performance
  • Manley Platinum Series Forged Pistons
  • Manley Turbo Tuff I-Beam w/ ARP Rod Bolts
  • ACL Race Bearings
  • New OE Heat Treated Crankshaft
  • BC 280 Cams
  • GSC Intake & Exhaust Valves +1mm
  • GSC Beehive Valve Springs & Retainers
  • GSC Intake & Exhaust Valve Guides
  • GSC Viton Valve Stem Seals
  • JE Pro Seal .039 Head Gaskets
  • Gates Racing Timing Belt
  • Tomei Timing Belt Guide
  • Killer B Oil Pan
  • Killer B Baffle
  • Killer B Oil Pickup
  • ARP 625+ Head Studs
  • IAG Air Pump Block Off Plates
  • GrimmSpeed EBCS
  • COBB Fuel Pressure Sensor
  • IAG TGV Deletes
  • Visconti Tuning Speed Density Kit
  • AEM 5 Bar MAP Sensor w/ IAG Adapter
  • ETS Front Mount Intercooler 4" core, black anodized
  • ETS Rotated Kit with PTE 6466
  • Killer B Holy Header 2 bolt
  • Subispeed Catback Exhaust w/ vibrant resonator
  • Radium Dual Hanger Fuel Pump System
  • Dual walbro 450 e85 pumps
  • Aeromotive -6 Fuel Pressure Regulator
  • -8AN feed line
  • -6AN return line
  • Injector Dynamics 2000cc
  • IAG Fuel Rails
  • Assorted Fittings and JEGS Fuel Lines
  • Fuelab In-Line Fuel Filter
  • Zeitronix Ethanol Analyzer
  • IAG Perfomance Competition AOS
  • Morosso Catch Can
  • Fumoto Oil Drain Valve
  • Perrin Brake Reservoir Kozy
  • Perrin Boost Control Cover
  • Perrin Radiator Shroud
  • Perrin Belt Cover
Drivetrain:
  • Torque Solutions Engine & Transmission Mounts
  • Perrin Pitch Stop Mount
  • Kartboy Short Throw Shifter
  • Kartboy Shifter Bushings
  • Mach V Awesome Wheel 17x9 +42
  • Nitto nt555r 245/45r17
  • Competition Clutch Stg 5 four puck
Suspension:
  • RCE Yellow Springs
Exterior:
  • Bayson-R Front Lip
  • HT Autos V1 Rear Spats
  • JDM Sports Grille
  • STI Black Fender Emblems
  • Diode Dynamics Tail as Turn Module
  • OLM LED License Plate Full Replacement Housing
  • LED Turn Signal Bulbs
  • 15% & 10% tint
  • Torklift Eco Hitch
  • Diode Dynamics Switchback C-Lights
Interior:
  • Cubbypod Dual 52mm Pod
  • Prosport 52mm Amber/White Oil Temp Gauge
  • Prosport 52mm Amber/White Oil Press Gauge
  • Prosport 52mm Amber/White Fuel Press Gauge
  • AEM Wideband UEGO A/F Gauge
  • AEM Boost Gauge -30 to 50 psi
  • SMY Performance Dual Gauge Pod Cluster
  • SMY Performance Accessport Mount
  • SMY Performance Door Striker and Hinge Cover
  • SMY Performance Climate Control Knob Covers
  • SMY Performance Defroster Vent Gauge Pod
  • JDM Center Display Cover
  • JDM Fuse Cover Coin Tray
  • Billet Aluminum Extended Throttle Pedal
  • WeatherTech Floor Mats w/ STI logo
  • OLM LED Trunk Light
  • OLM LED Interior Map / Dome Lights
Dampa's CBS '15 STI **Closed deck/PTE6466**-15d7e7b7-28cc-489c-87ed-ac72890ff983_zpsiza0gvfa-jpg
Dampa is offline
Likes 4 Dislikes 0
Sponsored Links
Advertisement
Old 02-22-15, 10:51 AM   #2
Dampa
Fav Mod: E85
My Threads
Default Re: Dampa's '15 STI Build
Dampa is offline
Likes 2 Dislikes 0
Old 02-22-15, 10:57 AM   #3
Dampa
Fav Mod: E85
My Threads
Dampa is offline
Likes 1 Dislikes 0
Sponsored Links
Advertisement
Old 02-22-15, 11:06 AM   #4
Dampa
Fav Mod: E85
My Threads
Dampa is offline
Likes 0 Dislikes 0
Old 02-22-15, 11:19 AM   #5
Dampa
Fav Mod: E85
My Threads
Dampa is offline
Likes 1 Dislikes 0
Old 02-22-15, 11:42 AM   #6
erosti2015
My Threads
erosti2015 is on a distinguished road
Nice car. I'm located in NM as well... About 90 miles north of you.
erosti2015 is offline
Likes 0 Dislikes 0
Old 02-22-15, 04:25 PM   #7
GBPSTI
Advanced Contributor Level 1
Car: 2015 GBP STI
Fav Mod: Driver
My Threads
GBPSTI is on a distinguished road
Car looks OUTSTANDING in that color !! Especially tinted up.
GBPSTI is offline
Likes 0 Dislikes 0
Old 02-22-15, 05:05 PM   #8
Dampa
Fav Mod: E85
My Threads
Where are you located at, you getting a lot of snow up there? Not too many '15's in NM that I've seen, only seen two other '15 STI's in town...
Thanks! I think these cars look awesome in every color, I don't think I've seen one picture where I don't like them hahaha. I keep seeing other colors and it makes me question my color choice until I look at my car and it starts all over again.
Dampa is offline
Likes 0 Dislikes 0
Old 02-22-15, 06:34 PM   #9
Nachos Libres
Moderator Elite
Feedback Score: 2 reviews
Fav Mod: Non-Subaru Paint
Nachos Libres is a jewel in the roughNachos Libres is a jewel in the roughNachos Libres is a jewel in the rough
Nice.
Nachos Libres is offline
Likes 0 Dislikes 0
Old 02-22-15, 07:23 PM   #10
erosti2015
My Threads
I'm just north of Santa Fe. It's flurrying right now but I don't expect any accumulation. I've only seen two STi's on the road: 1 launch edition and 1 CWP LE. I've seen less than a handful WRX's.
Likes 0 Dislikes 0
Sponsored Links
Advertisement
You may post new threads
You may post replies
Forum Jump
Similar Threads
GD: Soccer05 Bugeye Street/Track Build Thread, 2.5 L, Lic, MSI, JRZ, Carbon Widebody Soccer05 GD-Members' Journals 397 08-03-16 02:00 PM
07 Limited Build STILimited07 Built Motor Discussion 22 01-28-14 01:31 PM
108k Sti Build or new motor? isti10 Built Motor Discussion 8 12-10-13 08:54 PM
AMS Top Shop Engine build..the quest for 1000hp on 100octane! AMS Vendor Announcements & Project Buildups 8 11-05-08 04:58 PM
new engine build, and cost. what do you think? FizzyMilk 2.5 Liter/Litre Factory Motor 11 11-19-07 01:35 AM
Powered by vBulletin
