awenthol's 2013 DGM STi Sedan
Since Photobucket killed all of my links, the full build can be found here.
Build goal--fun toy that can handle weekends, track days and dragstrip as necessary.
INTERIOR
ELECTRONICS
-Passport Escort 9500ix Red
-Blackvue DR650GW-2CH
-Web Electric One Touch Turn Signal
-Nexus 7 32GB (2013)
-BTSSM + App
-Fortrin EVO-All
-Advanced Keys w/STi Push Button
-Braille BR14115 Lightweight Battery & Alum. Mount (trunk mount)
GAUGES:
-SMY Clustermaker
-JCS PODs Triple Pillar
-Defi Red Racer Boost
-Defi Red Racer Pressure (Oil)
-Defi Red Racer Temp (Oil)
-Defi Red Racer Pressure (Fuel)
-Defi Red Racer Pyrometer
-AEM Wideband
-Zeitronix ECA-2 (ethanol content analyzer)
LIGHTING
-Floor LED Bars
-LED Dome Lights
MISCELLANOUS
-GT Spec Wheel
-Armrest Extension
-JDM Radio Bezel
-JDM Start Button Bezel
-JDM Ignition Cover
-JPM Shifter Boot
-JPM E-Brake Boot
EXTERIOR
LIGHTING
-DIY Blacked Out Headlights
-OEM Fog Lights
-HIDs for fogs (5000K,9006)
-JDM Rear Fog Lens
-Rear Fog LED & Harness
-LED all the lights
-Lens Tint (Tails)
MISCELLANEOUS
-3M Clear Bra
-Tint (15% and 50% windshield)
-Hella Dual Horn Kit (hidden)
-Perrin Shorty Antenna
-PlastiDip (wheels/window sill)
DRIVETRAIN
SUSPENSION/CHASSIS/HANDLING
-Torque Solution Trans Mount
-Torque Solution Engine Mounts
-Torque Solution Pitch Stop
-STi Short Throw Shifter
-Kartboy Shifter Bushings
-Whiteline Positive Shift Bushings
-Whiteline Rear Diff Bushings
-Whiteline Rear Subframe Bushings
-Whiteline Rear Upper Control Arm Bushings
-SuperPro Rear Trailing Arm Bushing
-SuperPro Rear Toe Arm
-Atomic Fabrications Adjustable Trailing Arm
-Whiteline ALK
-Whiteline front Control Arm Bushings
-Whiteline Steering Rack bushing
-Cusco Steering Rack Brace
-Cusco Front Crossmember Power Brace
-SPT Front subframe brace
-Whiteline control arm plates
-DIY fender brace
-KartBoy End Links
-Eibach Sway Bar Kit F/R 25/22mm
-AVO Rear Sway Brackets
-RCE Yellows
-13.1:1 Steering Rack (2015 STi)
-Earl's Power Steering Cooler
-Chase Bays P/S Reservoir
-Earl's Pro Lite Ultra Hose and Ano-Tuff fittings
WHEELS
-Enkei PF01 EVO (18x9.5)
-Michelin Pilot Super Sports (275-35)
-Muteki Lug Nuts
-ARP Extended Lugs
BRAKING
-GrimmSpeed MBC Support
-Stoptech Brake Lines
-Stoptech Rotors
-Carbotech XP-10 pads
-Motul RBF660
ENGINE/TRANSMISSION
ECU/TUNING/ELECTRONICS
-Cobb AccessPort (AP2, SUB003)
-GrimmSpeed EBCS
BASE ENGINE
-Dan Benson Racing Sleeved/O-Ring'd block
-Manley 99.5mm pistons/rings (extreme duty)
-Manley Turbo Tuff I-Beam Rods (625+ bolts)
-Manley 79mm Crank (WPC'd)
-King XPG Main Bearings (std, WPC'd)
-King XPG Rod Bearings (std, WPC'd)
-ARP 625+ Case Bolts
-Subaru 11mm Oil Pump, Ported and WPC'd
-Eastwood Ceramic Engine Paint and Activator
-Wrist Pins and Rings WPC'd
-Piston Tops Coated with SwainTech Gold Coat
INTAKE/HEADS
-KS Tech MegaMAF intake
-Frozen Boost AWIC + Rear mount radiator
-Agency Power 3" Turbo Inlet
-GrimmSpeed 3mm Phenolic Spacer
-Throttle Body Coolant By-Pass (DIY)
-TGV Deletes and Manifold Port Matching (DIY)
-Throttle body port/polish (DIY)
-ARP 625+ Head Studs
-Kelford Cams (272/268) (DIY polished and WPC'd)
-Kelford Valve Springs
-Manley Intake/Exhaust Valves 36/33mm
-Ferrea Valve Keepers
-GSC Intake/Exhaust Valve Guides
-GSC Valve Seals
-TIC FU Cam Bolts
-JW Cylinder Heads Radius Valve Job/Porting
-Earl's Pro Lite Hose and Ano-Tuff fittings for breather
-SuperTech Valve Buckets
EXHAUST
-Killer B Holy Headers w/Swaintec
-Invidia Catless Downpipe w/extra O2
-DEI Heat Wrap & Silicone Coating
-Air Pump Delete
-Perrin Turbo Blanket
-GrimmSpeed Gaskets
-Kartboy Exhaust Hangers
-Corsa Cat-Back
-Vibrant E-Vac Scavenger Kit
OIL SYSTEM
-OEM Oil Cooler Delete (NA 2.5 pipe stand and block coolant plug)
-Moroso Oil Pan/Pickup
-Killer B Windage Tray
-Killer B Pan Hardware (Moroso studs were garbage)
-Vibrant EVAC for Breather
-Fumoto Oil Drain Valve
-Earl's Oil Cooler (Earl's -AN lines/fittings)
FUEL SYSTEM
-DeatschWorks 65c (hardwired)
-FID 1000cc Injectors
-IAG (damped) Fuel Rails
-Continental FF Sensor
-AEM Fuel Pressure Reg
-FueLab 6micron Fuel Filter
--6AN Earl's Pro-Lite Ultra Hose (tank to rails)
-Earl's Ano-Tuff Fittings
COOLING SYSTEM
-Koyo Aluminum Radiator
-Spal low profile fans (clear oil lines)
-Samco Radiator Hoses
-Killer B Dearation Tank (-AN fittings)
-Chase Bays Coolant Reservoir
-Earl's Pro Lite Hose (pump, tank, radiator, heater core, etc)
-Subaru Closed Impeller Water Pump
TRANSMISSION
-Exedy Triple Disc Clutch
-Exedy Throw Out Bearing
-ACT Monoloc
-Goodrich SS Clutch Line
-Cuircuit Motorsports Clutch Brace
-DSS Carbon Fiber Driveshaft
MISCELLANEOUS
-Fluidampr Crank Pulley
-Gates Racing Timing Belt Kit w/pump (drilled/tapped for -AN fittings)
-Gates Accessory Belt
-Gates Stretch Belt
-Tomei Timing Belt Guide
-Full engine cryo-treatment
-Variety of weight reduction...
INTERIOR
ELECTRONICS
-BTSSM + App
-Fortrin EVO-All
GAUGES:
-SMY Clustermaker
-AEM Wideband
LIGHTING
-Floor LED Bars
-LED Dome Lights
MISCELLANOUS
-GT Spec Wheel
-Armrest Extension
-JDM Radio Bezel
-JDM Ignition Cover
-JPM Shifter Boot
-JPM E-Brake Boot
EXTERIOR
LIGHTING
-OEM Fog Lights
-JDM Rear Fog Lens
-LED all the lights
-Lens Tint (Tails)
MISCELLANEOUS
-3M Clear Bra
DRIVETRAIN
-Whiteline ALK
-DIY fender brace
-KartBoy End Links
-RCE Yellows
WHEELS
-Muteki Lug Nuts
-ARP Extended Lugs
BRAKING
-Stoptech Rotors
-Motul RBF660
ENGINE/TRANSMISSION
-GrimmSpeed EBCS
BASE ENGINE
INTAKE/HEADS
-GSC Valve Seals
-TIC FU Cam Bolts
EXHAUST
-Air Pump Delete
-GrimmSpeed Gaskets
-Corsa Cat-Back
OIL SYSTEM
FUEL SYSTEM
COOLING SYSTEM
TRANSMISSION
-ACT Monoloc
MISCELLANEOUS
-Gates Stretch Belt
