GR Hatch: '08 JDM Sti - NZ Superlap 2018/19 - Subaru Impreza WRX STI Forums: IWSTI.com
STI Forum
Join
Go Back   STI Forums > > > GR Hatch: '08 JDM Sti - NZ Superlap 2018/19
Old 03-26-14, 05:08 PM   #1
JeremySmith220
Developing Advanced Mastery
Feedback Score: 0 reviews
Fav Mod: Borg Warner EFR7670
My Threads
My Subaru Parts for sale
JeremySmith220 is a glorious beacon of lightJeremySmith220 is a glorious beacon of lightJeremySmith220 is a glorious beacon of lightJeremySmith220 is a glorious beacon of lightJeremySmith220 is a glorious beacon of light
Default '08 JDM Sti - NZ Superlap 2018/19
Creating the street/competition GRB....turning slowly into a race car.
Current Tune (Nov 18) 516whp(385wkw), @ 28.9psi on E73
My 2008 GRB JDM Spec R Sti
Facebook: Smitho Racing - Home | Facebook '08 JDM Sti - NZ Superlap 2018/19
Youtube: Jeremy Smith - YouTube
Modification List
ENGINE MANAGEMENT
Emtron Australia KV8 MY07-14 Plugin Engine Management
Emtron Excess Loom for extra inputs - Lambda & Oil Temp
Emtune Logging and Motorsport Control
Toshiba 8" Tablet for Live Data Dash and PC Logging/Tuning
Protuned on 98 Octane (E10)
Defi External Oil Pressure Sensor
Defi External Fuel Pressure Sensor
Defi External Oil Temperature Sensor
Bosch LSU 4.9 Lambda Sensor for closed loop lambda fuel control
HV Electronics Intake Air Temperature Sensor
HV Electronics Flex Fuel Sensor
EFR Turbo Speed Sensor
Fullriver HC20 680CCA High Crank battery
Narva Battery Isolation Switch.
ENGINE BLOCK
NEW Subaru Semi-closed v7 EJ207 Engine Block
Eagle H-Beam Conrods
JDM STI Forged Pistons ported for Oversize valves
ACL race bearings
New OEM 2.0L crank
Subaru Group N Engine Mounts
Subaru Group N Transmission Mount
Kartboy Engine Pitch Mount
OIL SYSTEM
12mm Oil Pump
Black IAG Competition Air / Oil Separator
Killer B Motorsport V2 Performance Oil Pan
Motul 300V 15W50/20W60 Oil
Mocal non-thermostatic Sandwich Plate
Setrab Series 6 - 19 Row Oil Cooler
Koyorad 15 Row Oil Cooler - Run in series
Delete Factor Modine and Oil Cooler
Speedflow Oil Cooler Lines and Fittings
Custom Front Mount oil cooler bracket & ducting
HEAD
V11 Heads with Porting
H11mm Head Stud Kit
Kelford 282 Race D-Shaped Cams
Ferrea 1mm Oversize Valves
FUEL
Bosch Motorsport 1650cc Injectors
Denso IKH27 Spark Plugs
AEM 320lph E85 feed Fuel Pump
Custom external mounted Surge Tank with Dual Bosch 044 Fuel Pumps
Aeromotive 40mm Dual Fuel Filters
Aeromotive A1000-6 Fuel Regulator
Speedflow fuel rails, lines and fittings
98 Octane Fuel (93 Octane US equivalent)
IAG V2 Parallel Top Feed Fuel Rails - Black
INDUCTION
Borg Warner EFR7670 Turbo 1.05 A/R T4 Twin Scroll (external WG)
PTP T4 Lava Turbo Beanie
Custom Exhaust Up and 3" Down pipe
Custom Plenum Chamber for Intake Manifold
Deleted TGV and Ported Bolt on Adaptors - Emission sensors disabled
LINK 4 Bar MAP Sensor
Tial 44mm MVR EWG
Adrenalin R 3" Exhaust - Straight through piping.
HKS Racing Suction R Intake with K&N Filter
Custom Cold airbox for intake and oil cooler
600x300x100mm Custom Front mount Intercooler & piping with DEI Reflect-a-gold Tape heat wrapping.
Black Silicon Intercooler Joiners / Wurth Hose Clamps
Koyo Racing Radiator - Dual Core
Perrin Performance Radiator Shroud
Rallytech UK Carbon Reverse Scoop
DRIVE TRAIN
JDM 6 Speed Manual Transmision
Motul Synthetic 75W90 Gear Oil
Stock Front and Rear Differential�s
Custom Driveshaft loops x 2
Exedy Single Plate HD Clutch & Machined Lightweight Flywheel
STI Brembo 4 Pot Front and 2 Pot Rear Brakes
APR Carbon Brake Duct Plates Front
Racetech Brake & Oil Cooler Ducts
Girodisc 2 piece Front Rotors
DBA T2 Street Series Slotted Rear Rotors
Motul 600 Dot 5.1 Brake Fluid
Endless ME22 Front Pads
Endless MX72 Rear Pads
New Relocated Teflon Power steering lines
SUSPENSION / HANDLING
JDM 13:1 Steering Rack
Sti Front Lip
Whiteline 22mm Front and Rear Sway Bars
Whiteline Front Control arm - lower inner rear bushing (anti-lift/caster correction)
Whiteline Front Roll centre/bump steer - correction kit
Whiteline Front lower control arm brace
Whiteline Front Strut Tower Brace
Blitz Rear Miracle Camber Adjusters
MCA Red Coilovers 11k Front, 12k Rear
WHEELS / TYRES
Work Emotion 11R 18x9.5" Wheels
Yokohama Neova AD08R 265/35R18 Tyres
Work Emotion CR Kiwami 18x9.5” Wheels
Hankook Z221 C70 265/35R18 Tyres
INTERIOR
Racetech 4119WTHR Drivers Seat
Racetech 4009WSTLH Passenger Seat
Racetech Alloy Seat Brackets
Octane Automotive Chromoly Multi Point (8+) Roll Cage
Full Interior Paint in Midnight Blue
OMP Seat Harnesses 0204
OMP Velocita Steering Wheel, Suede, 350mm with Lifeline Quick Release & NRG Boss
Lifeline 2.4L AFFF Handheld Fire Extinguisher.
JDM Sti Push Button Start
AVS A5 Car Alarm
JDM Sti 2 Bar Boost Gauge (Metric: Bar)
Defi Red Racer Oil Pressure Gauge (Metric: Bar)
Bel STi Magnum Radar Detector
GoPro 3 & 5 - Roll Cage Mount/Suction Cup
VBOX Sport - Data Logger
Ram Composite Twist Lock Suction Cup iPhone Mount with Universal X-Grip
Harrys Laptimer Grand Prix Edition
Driver Mod
Power Journey
New Tune Oct 2017: 468whp, 456wtq @ 29.5psi
Old Kelford 282's Tune: 481whp, 437wtq @29.25psi
Kelford 272's: 494whp 446wtq @ 31.7psi
http://i.imgur.com/AwJ9XUH.jpg
401whp 329wtq (Limited by Tuner to be safe with Factory ECU)
http://i.imgur.com/xV1XZ9h.jpg
Exhaust + Air Filter + Tune: 269whp
http://i.imgur.com/tJ0974M.jpg
Stock: 227whp
'08 JDM Sti - NZ Superlap 2018/19-2eecba64a39457319e0eed1ddfba4a2b-jpg
JeremySmith220 is offline
Likes 5 Dislikes 0
Sponsored Links
Advertisement
Old 03-26-14, 05:26 PM   #2
user1029
Advanced Mastery Level V
Feedback Score: 5 reviews
Fav Mod: HTA86.
user1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud of
Default Re: 2008 JDM Spec Spec R STI - Built Motor - Goal 500 whp
Nice man, good luck with the build!
I would recommend
1. Manley Turbo Tuffs rods
2. ARP Age 625 studs
3. ID1300cc injectors
4. ACT 6puck clutch
5. KillerB oil pickup, air pump delete, etc
Hopefully the shop offers a warranty on top of all that
user1029 is offline
Likes 2 Dislikes 0
Old 03-26-14, 05:45 PM   #3
JeremySmith220
My Threads
Default Re: 2008 JDM Spec R STI - Built Motor - Goal 500 whp
Thanks! Cant wait
Likes 0 Dislikes 0
Sponsored Links
Advertisement
Old 03-26-14, 06:21 PM   #4
JeremySmith220
My Threads
Current Dyno Sheet for interest - attached to the main post.
Likes 0 Dislikes 0
Old 03-26-14, 06:33 PM   #5
Dspin_1080
Advanced Mastery Level IV
Car: Carless
Fav Mod: Would rather answer a quantum physics question...
Dspin_1080 is on a distinguished road
A few parts here are really grabbing my attention
Should be a good one to keep an eye on
Good luck and welcome to IWSTI, OP
Dspin_1080 is offline
Likes 1 Dislikes 0
Old 03-26-14, 06:44 PM   #6
JeremySmith220
My Threads
Thanks a lot, been on this site a lot admiring the builds on here, only just got around to making my own journal.
I want to do this properly and avoid another blown motor if possible. So i try and steer towards the quality parts.
Likes 0 Dislikes 0
Old 03-27-14, 06:45 AM   #7
user1029
Fav Mod: HTA86.
**PSA** So you have a >400whp fully built setup: Protecting Your Investment
user1029 is offline
Likes 1 Dislikes 0
Old 03-30-14, 12:39 PM   #8
JeremySmith220
My Threads
Does anyone else here have the HKS SuperTurbo Exhaust, will it be restrictive for a high power application? I have been told I will need a 3.5" Custom Exhaust to make the most power. Comments appreciated. Thanks!
Likes 0 Dislikes 0
Old 03-30-14, 06:26 PM   #9
JeremySmith220
My Threads
This car is my goal....
Carl Ruiterman Drifting Promotional Video December 2013 - YouTube
Likes 2 Dislikes 0
Old 04-01-14, 08:56 PM   #10
JeremySmith220
My Threads
Default Re: 2008 JDM Spec R STI - Built Motor, Race Cam, HKS, Excedy, Motul, ACL and Eagle
Car going in for 2nd stage of build next week, will be at the tuners for 3 weeks, cant wait to see the results!
Likes 0 Dislikes 0
Sponsored Links
Advertisement
Forum Jump
Similar Threads
IAG built 2008 STi, 35R, Built Motor, 93 oct, 50/50 meth: 502whp DD user1029 Power Bragging 20 05-23-13 01:03 PM
FS (USA,VA): FULL INTERIOR JDM Black alcantara Spec C RA-R v9 xpsychovampyrox Interior Parts For Sale 1 02-11-13 03:24 AM
FS (USA,CA): Built OBP 2008 STi Im2ninja4u Used STIs For Sale 7 06-30-11 12:56 PM
My 2008 STi - Completely Built by GReddy Performance Products Marcus GR-Members' Journals 64 09-15-09 05:00 PM
FS:(NY) Custom Built Innovative 67 Trim Turbo and 50 Trim.. WHP!!! IwannaSubi Engine/Drivetrain/Performance Parts For Sale 0 06-30-08 11:22 AM
Powered by vBulletin
