GR Sedan: Stealth-baru! IAG S2 Tuff | EFR7163 | Ohlins | HFS-3 Meth - Subaru Impreza WRX STI Forums: IWSTI.com
STI Forum
Join
Go Back   STI Forums > > > GR Sedan: Stealth-baru! IAG S2 Tuff | EFR7163 | Ohlins | HFS-3 Meth
Old 02-19-14, 07:31 AM   #1
sti_mtl
Gold Member
Feedback Score: 2 reviews
Fav Mod: efr 7163
My Threads
My Subaru Parts for sale
sti_mtl is a jewel in the roughsti_mtl is a jewel in the roughsti_mtl is a jewel in the roughsti_mtl is a jewel in the rough
Talking Stealth-baru! IAG S2 Tuff | EFR7163 | Ohlins | HFS-3 Meth
This car is a labor of love. Behold!
Black=Installed
Green=Being installed meow
Fuel & Tuning:
-Cobb Accessport Pro Tune done by Lachute Performance
-Break in Started at 91255km
-1200km on Break in Tune; completed
Stock STI on MAHA:
-280.8 lbf.ft TQ @ 3445rpm (crank)
-294.4 HP (crank)
-195.8 HP (wheel)
-91 octane
Stage 3 tune (previous tune):
-400 lbf.ft TQ @ 3955rpm (crank)
-394.2 HP (crank)
-288.4 HP (wheel)
-94 Petro Can
Current Tune (MAHA dyno):
-444.1 lbf.ft TQ @ 4365rpm (crank)
-503.3 HP (crank)
-365.3 HP (wheel)
-94 Petro Can+50/50 meth (boost juice)
@21psi
Current Tune (Dynojet):
-421 lbf.ft TQ
-424 WHP
This is a virtual dyno 4th gear pull, in dynojet mode.
The Lachute Maha dyno can be difficult to compare to others,
however it seems more conservative than a mustang dyno,
so virtual dyno is handy for comparison.
Exhaust / Intake:
-custom Lachute Performance rotated catted downpipe
-custom Lachute Performance uppipe (ewg rerouted)
-custom Lachute Performance rotated Cold air intake+kstech heat shield
-Killer B Motorsport 4-1 Holy Header 2-Bolt Subaru (black ceramic coating)
-Invidia q300 exhaust (with titanium finish)
-q300 resonator swapped for magnaflow #14329
-Tial 44mm ewg
-dei titanium wrap on up pipe+downpipe+headers
-Tomioka bellmouth catted downpipe+dumptube Reroute
-GrimmSpeed UpPipe, with black ceramic coating (dumptube rerouted to Downpipe)
-Grimmspeed IWG bracket
-DEI Header Wrap, on downpipe and uppipe
-KS Tech MegaMAF 73mm Big MAF Cold Air Intake (Type 2)
-Perrin Performance Turbo Inlet Hose WRX 2002-2007 / STI 2004-2015 Color Inlet
Engine/Turbo:
-Aquamist HFS-3 version 3.1
-Prometh 4.2 gallon tank (50/50 mix) stealthily mounted in spare tire space
-efr 7163 0.85 vband (ceramic coated by Release Coatings)
-IAG stage 2 tuff shortblock
-Manley 99.75mm Platinum Series Pistons, Ringset, Tool Steel Pins and Clips (w/ Coated Skirts and Offset Wrist Pin)
-IAG Spec Bore and Hone (Performed on our in house Sunnen SV-10)
-Tighter piston to wall clearance for quiet operation
-New FHI Subaru Case Halves (Bored, Honed and Plateau Brushed)
-Manley H-Tuff Forged Connecting Rods w/ ARP Rod Bolts (Heavier Version of H-beam Rods)
-New FHI Subaru Heat-Treated 2012+ STI Crankshaft
-ACL Race Rod Bearings
-ACL Race Main Bearings
-New FHI Main Case Bolts
-Lachute Refreshed heads (with 3 angle valve job)
-Brian Crower springs
-IAG tgv deletes
-IAG phenolic spacers
-IAG Competition series AOS
-IAG v2 top feed fuel rails
-Injector Dynamics 1000cc injectors
-Aeromotive 325 Stealth Fuel pump
-ETS TMIC (+gold tape, STI stencil)
-Koyo aluminum racing rad
-killerb ultimate oil pickup
-PtP Turbo blanket (efr B1)
-New oem Sti 11mm Oil Pump+gasket/seal
-New oem water pump+gasket
-Gates timing Belt Kit
-Air Pump Delete (IAG Plates, Red)
-Aeromotive FPR orb6 (solved fuel stutter @ 2800rpm)
-Optima Yellow Top battery D35
-Grimmspeed EBCS
-Cobb Fuel Pressure Regulator Kit
-Grimmspeed Turbo Heatsheild
-PTP Turbo Blanket
-Cusco catch can
-NGK Iridium Spark Plugs One Step Colder (#2309)
-KHC1400r High current Car audio Battery
Drivetrain:
-STI 2015 13:1 steering rack (on my second 13:1 rack now)
-master cylinder clutch brace (circuit motosports)
-Perrin Reverse Lockout Lever
-TWM Short throw shifter
-TWM front and rear stay bushing kit
-Group N Subaru 6-Speed Transmission Mount
-Group N Subaru Engine Mount Set
-Kartboy Engine Pitch Stop Mount
-Whiteline KDT901 Positive Shift Kit
-Bully clutch (stage 3)
-refinished flywheel
-GoodRidge Stainless Steel Coated Clutch Line STI 24222-CLU-STI
-Whiteline Rear Differential Mount Inserts Positive Power Kit KDT903
-Cusco Power Steering Rack Brace 692026ALHD
-SuperPro Rear Subframe Insert Kit 2008-2014 WRX & STI SPF3831K
-SuperPro Steering rack bushings
Suspension+Brakes:
-DBA 4000 t3 slotted rotors (front+back)
-Ohlins Road and Track Coilovers+Ohlins Topplates
-Grimmspeed Master Cylinder Brace
-RCE tarmack 2 coilovers
-Vorshlag Camber Plates
-Super Pro Front Control Arm rear Duroball no caster (DURO3736k)
-Swift Spec-R Springs - 2008-2013 Subaru WRX STi
-Whiteline KCA409 Front Com C Strut Mounts - 2008-2014 Subaru WRX STi
-Whiteline BSF39XZ 24mm Adjustable Front Sway Bar - 2008-2013 Subaru WRX STi
-Whiteline BSR49XZ 22mm Adjustable Rear Sway Bar - 2008-2013 Subaru WRX STi
-Kartboy endlinks (front+rear)
-Powerflex Powerflex Rr Upp Arm Inner Rr Bushes Adj PFR69-511G
-Ferodo DS2500 Rear Brake Pads Subaru
-Ferodo DS2500 Front Brake Pads Subaru STI
-Stoptech Stainless Steel Brake Lines Front Subaru Models*
-Stoptech Stainless Steel Brake Lines Rear Subaru STI 2008-2014
-Super Pro Front Inner Bushings (spf3728k)
-Whiteline Anti Lift Kit Race Version Manufacturer Part # KCA425M
-Super Pro Roll Center Correction Adjustment Kit (Bump Steer Correction) TRC0002
Wheels & Tires:
-Summer:
-Bridgestone Potenza Re-11a 265/35/18
-Weds Sa-15r Gunmetal Bronze/Black 18x9.5 (5x114.3) +38 offset
-Winter:
-hakkapelita 9 (Studded) 245/40/18
-Stock Rims (gunmetal)
ICE/Security
-Pioneer 8000nex Headunit
-rockford fosgate t1675s (front speakers+tweeters)
-rockford fosgate p2d4-10 sub
-rockford fosgate R500xd1 mono amp
-rockford fosgate R600-4d amp
-rockford fosgate p165 rear speakers
-SiriusXM SXV200v1 Tuner
-ASWC-1 Steering wheel control (from SVXDC)
-Harness to interegrate into existing speaker setup
-MHL 2.0 HDTV Smart Adapter (adapter for note3) ( ET-H10FAUWESTA)
-Pioneed CD-AH200 (adapter for appradio on 8000nex)
-AUX 3.5mm harness (allows use of audio jack with HU) svxdc
-OBDlink mx bluetooth (digital gauges via Dashcommand/appradio)
Interior:
-Defi Red Racer White Pointer Fuel Pressure Gauge (52mm)
-SMY Defroster Vent 52mm Gauge Pod
-TWM Shift Knob (Big Type R RL)
-Redline Shift and ebrake boot, done in alcantara with red perforated leather stripe)
-Weathertech custom fit black floormats
-DAMD D shaped steering wheel (red stitch)
-HU Bezel+Shift boot bezel Hydrographics (carbon fiber)
-Steering wheel center vinyl overlay (from crux motorsports)
-JDM Armrest
-SMY Dual Gauge Pod 2008-2014 WRX & STI (Wrapped in Alcantara Suede) WITH LOGO
-Innovate Motorsports SCG-1 All-in-one, intelligent boost controller and wideband air/fuel ratio controller
-Innovate Motorsports MTX Digital Series "Dual Function" Gauges Oil Pressure & Oil Temperature 3852
-Prova Anti-Bacterial Deodrizing Cabin Filter
-4 doors+A pillars+trunk deck soundproofed (dynamat+closed cell foam)
Exterior:
-Prolightz Fog light kit
-MORIMOTO XB LED FOG LIGHTS
-Lower Rear Brake Light (from avoJDM)
-Spoiler Removed (bought a trunk lid, and had it painted)
-R205 Side Badges
-Subtle solutions front plate delete piece+red accent
-custom 'spec. EFR' badge on trunk
-Badges on trunk deleted (all except STI)
-Rally Armor Mud Flaps
-Xpel Ultimate clear bra on front bumper, hood, mirrors, and scoop
-Window chrome delete vinyl (from premiumautostyling)
-Smoked tail light overlays (from premiumautostyling)
-HT Auto Subaru front sport grill (painted OBP)
-HT Auto front lip
-HT Auto rear lips/spats
-HT Auto rear diffuser
-Grillcraft Lower front grill
-Grillcraft Hoodscoop grill
-Hella Supertones+Subimods Hella Horn Bracket and Wiring Harness
-Beatrush rear tow hook (Black+red)
Engine Dress Up:
-Grimmspeed Alt Cover (red)
-Grimmspeed Rad Shroud (red)
-Grimmspeed Oil Cap (red)
-Perrin EBCS cover (red)
-JDM Battery Cover
-JDM ABS Cover
-IAG Billet Aluminum Power Steering Cap v2 (red)
-IAG Billet Aluminum Windshield Washer Cap v2 (red)
-IAG Billet Aluminum Coolant Overflow Cap v2 (red)
- x2 STI Radiator Cap Billet Aluminum (Red Anodized)
Stealth-baru! IAG S2 Tuff | EFR7163 | Ohlins | HFS-3 Meth-front-jpg   Stealth-baru! IAG S2 Tuff | EFR7163 | Ohlins | HFS-3 Meth-back-jpg
sti_mtl is offline
Likes 8 Dislikes 0
Sponsored Links
Advertisement
Old 02-19-14, 07:32 AM   #2
sti_mtl
Gold Member
Fav Mod: efr 7163
My Threads
Default Re: Stealth-baru! 2012 OBP Wingless STI
Reserved
sti_mtl is offline
Likes 1 Dislikes 0
Old 02-19-14, 08:51 AM   #3
HeatSource
Advanced Mastery Level I
Feedback Score: 4 reviews
Car: '99 RBP RSTi coupe
Fav Mod: EJ207
HeatSource is on a distinguished road
beautiful car man! welcome!
HeatSource is offline
Likes 0 Dislikes 0
Sponsored Links
Advertisement
Old 02-19-14, 09:03 AM   #4
asthmatic
Contributor
My Threads
asthmatic is an unknown quantity at this point
Nice, for some reason, after looking at your stealth pics, I have an urge to data log. Idk why.
asthmatic is offline
Likes 0 Dislikes 0
Old 02-19-14, 01:15 PM   #5
sti_mtl
Gold Member
Fav Mod: efr 7163
My Threads
Ty Sir
Nice to know my car brings on the desire to data log
sti_mtl is offline
Likes 0 Dislikes 0
Old 02-19-14, 01:55 PM   #6
Dspin_1080
Advanced Mastery Level IV
Feedback Score: 0 reviews
Car: Carless
Fav Mod: Would rather answer a quantum physics question...
Dspin_1080 is on a distinguished road
Bienvenue !
Congrats on starting your Journal
Looking forward to what comes next
Dspin_1080 is offline
Likes 0 Dislikes 0
Old 02-19-14, 02:26 PM   #7
sti_mtl
Gold Member
Fav Mod: efr 7163
My Threads
Originally Posted by Dspin_1080 View Post
Bienvenue !
Merci!
Saw your car last week in the lachute performance lobby, and all I can say is wow.
J'ai capoté lol.
Have since read through your journal. Very impressive.
Read the aim tech booklet in the lobby at lachute, and in your build thread. Absolutely cutting edge.
So sad to learn the great white perished in that fire at lachute awhile back, brought a tear to my eye. But looks like the garage has rebuilt twice as nice, as has your car. The nicest sti i have ever had the pleasure of seeing in person
sti_mtl is offline
Likes 1 Dislikes 0
Old 02-19-14, 03:07 PM   #8
Dspin_1080
Car: Carless
Wow............................................... .
uhmm... !??
Looking forward to meeting and thanking you in person, Kind Sir
Likes 0 Dislikes 0
Old 02-19-14, 03:55 PM   #9
Zeu$
Advanced Contributor Level 1
Car: Turbocharged
My Threads
Zeu$ is an unknown quantity at this point
Nice car!
The wingless looks awesome, I think it really gives these cars a slick look.
Zeu$ is offline
Likes 0 Dislikes 0
Old 02-19-14, 05:28 PM   #10
sti_mtl
Gold Member
Fav Mod: efr 7163
My Threads
For sure bro, hopefully ill run into you at lachute sometime, ill be up there in a week or 2 to get my new mods installed. My girl will be having our first baby early march so that might put a delay on my plans, but ill give u a shout when ill be around there.
sti_mtl is offline
Likes 0 Dislikes 0
Sponsored Links
Advertisement
Forum Jump
Similar Threads
SOLD: *Delete* tougestar Exterior Parts For Sale 3 11-02-13 10:24 AM
FS (USA,IL): Sold: (CHI) 06 OBP Wingless Trunk and Limited Spoiler IwantMySTI05 Exterior Parts For Sale 1 08-30-11 07:03 PM
(NY) OBP Wingless Trunk, OBP Roof Vane Spoiler, 04/05 Tails ArMiXiA WTB/WTT Classifieds 2 03-08-11 10:45 AM
CO--- WTT OBP Wing for 06' Wingless mainb57 WTB/WTT Classifieds 2 04-29-06 10:04 AM
WTT: OBP sti trunk 4 OBP wingless trunk - NY fourortwowheels USA - Northeast 0 04-16-06 12:02 AM
Powered by vBulletin
